Salta al contenuto principale
Asus A52F Cooling System Replacement
Cosa ti serve
  1. Asus A52F Cooling System Replacement, Battery: passo 1, immagine 1 di 2 Asus A52F Cooling System Replacement, Battery: passo 1, immagine 2 di 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F Cooling System Replacement: passo 2, immagine 1 di 2 Asus A52F Cooling System Replacement: passo 2, immagine 2 di 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F Cooling System Replacement, Lower Case: passo 3, immagine 1 di 3 Asus A52F Cooling System Replacement, Lower Case: passo 3, immagine 2 di 3 Asus A52F Cooling System Replacement, Lower Case: passo 3, immagine 3 di 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F Cooling System Replacement: passo 4, immagine 1 di 2 Asus A52F Cooling System Replacement: passo 4, immagine 2 di 2
    • Slide the back panel away and remove the panel.
  5. Asus A52F Cooling System Replacement, Cooling System: passo 5, immagine 1 di 2 Asus A52F Cooling System Replacement, Cooling System: passo 5, immagine 2 di 2
    • Removal of cooling system will void your warranty. Proceed with caution.
  6. Asus A52F Cooling System Replacement: passo 6, immagine 1 di 2 Asus A52F Cooling System Replacement: passo 6, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove all six screws from the cooling system.
    • Unplug the fan power connector.
  7. Asus A52F Cooling System Replacement: passo 7, immagine 1 di 2 Asus A52F Cooling System Replacement: passo 7, immagine 2 di 2
    • Carefully grab the copper pipe and start to lift upward.
    • Lift to the angle shown and then start to slide it out.
  8. Asus A52F Cooling System Replacement: passo 8, immagine 1 di 1
    • Clean the designated area with isopropyl alcohol on a microfiber cloth
    • Replace with new thermal paste if needed
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 39
Tutti i Tempi: 1,240
