Salta al contenuto principale
Asus 1015E-DS03 Screen Replacement
Cosa ti serve
  1. Asus 1015E-DS03 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Screen Replacement: passo 2, immagine 1 di 1
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Screen Replacement: passo 3, immagine 1 di 1
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Screen Replacement: passo 4, immagine 1 di 1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Screen Replacement, Front Screen Case: passo 5, immagine 1 di 1
    • Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
    • While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
  6. Asus 1015E-DS03 Screen Replacement: passo 6, immagine 1 di 2 Asus 1015E-DS03 Screen Replacement: passo 6, immagine 2 di 2
    • Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
    • You will hear popping noises which are to be expected.
  7. Asus 1015E-DS03 Screen Replacement: passo 7, immagine 1 di 1
    • When the screen case has been successfully removed, the laptop should resemble the photo shown here.
  8. Asus 1015E-DS03 Screen Replacement, Screen: passo 8, immagine 1 di 1
    • Unscrew the 3 mm screws (4) using a #0 Phillips head screwdriver.
  9. Asus 1015E-DS03 Screen Replacement: passo 9, immagine 1 di 2 Asus 1015E-DS03 Screen Replacement: passo 9, immagine 2 di 2
    • Lift the screen away from the computer.
    • Be careful removing the screen, as the left side is still connected to the computer.
  10. Asus 1015E-DS03 Screen Replacement: passo 10, immagine 1 di 2 Asus 1015E-DS03 Screen Replacement: passo 10, immagine 2 di 2
    • Remove the wire that is glued to the back of the screen with your fingers.
    • Remove the tape covering the connection port.
  11. Asus 1015E-DS03 Screen Replacement: passo 11, immagine 1 di 1
    • Separate the screen from the computer by gently pulling it out.
  12. Asus 1015E-DS03 Screen Replacement: passo 12, immagine 1 di 1
    • Upon removal, the computer should look like this picture.
Conclusione
Altre 2 persone hanno completato questa guida.
Becca Day
Membro da: 03/23/16
297 Reputazione
2 Guide realizzate
Clemson, Team 7-4, Benson Spring 2016 Membro di Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 592
