Introduzione
This guide will demonstrate how to remove the motherboard. A spudger and screwdriver will be used.
Cosa ti serve
Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
Remove the 3mm screws (8) from the motherboard using a #0 Phillips head screwdriver.
Carefully and slowly lift the motherboard out of the base of the laptop.
Altre 2 persone hanno completato questa guida.
