Salta al contenuto principale
Astro A50 Channel Selection Switch Replacement
Cosa ti serve
  1. Astro A50 Channel Selection Switch Replacement, Channel Selection Switch: passo 1, immagine 1 di 2 Astro A50 Channel Selection Switch Replacement, Channel Selection Switch: passo 1, immagine 2 di 2
    • Remove the foam ear padding by pulling it straight to you
  2. Astro A50 Channel Selection Switch Replacement: passo 2, immagine 1 di 1
    • Remove the four 3.5mm Phillips head screws circled in red, and remove the grey cover.
  3. Astro A50 Channel Selection Switch Replacement: passo 3, immagine 1 di 1
    • Remove the four 3.5mm Phillips head screws circled in red and remove the silver cover.
  4. Astro A50 Channel Selection Switch Replacement: passo 4, immagine 1 di 2 Astro A50 Channel Selection Switch Replacement: passo 4, immagine 2 di 2
    • Remove the four 3.5mm Phillips head screws.
    • Remove the 3.5mm Phillips head screw circled in blue to remove secondary motherboard.
  5. Astro A50 Channel Selection Switch Replacement: passo 5, immagine 1 di 1
    • Separate the secondary mother board from the motherboard by pulling firmly to the right on the white connector.
  6. Astro A50 Channel Selection Switch Replacement: passo 6, immagine 1 di 1
    • Finally push the channel selector in towards the motherboard to remove it from the headset casing. The switch is pointed to by the screwdriver inside the red square.
Conclusione
IUPUI, Team S1-G1, Baechle Fall 2017 Membro di IUPUI, Team S1-G1, Baechle Fall 2017
IUPUI-BAECHLE-F17S1G1
2 Membri
6 Guide realizzate
3 Commenti
This is great, thank you. My switch has been broken for two years, now I can get to fixing it.
Question: Once we have taken it apart, do we simply replace the switch or is there a contact on the switch itself, PCB or wire that needs to be re-attached or adjusted?
Thanks!
-Brandon
Brandon Thomas - Replica
where did you get the part to replace it? Can’t find just the little switch anywhere.
Justin Sykes -
This is perfect. But where do you get a new switch? Can’t find just the tiny part anywhere.
Justin Sykes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,288
