Salta al contenuto principale
Astro A40 TR Plus Mixamp M80 Headband Replacement
Cosa ti serve
  1. Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: passo 1, immagine 1 di 3 Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: passo 1, immagine 2 di 3 Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: passo 1, immagine 3 di 3
    • Use a screwdriver with a H2.0 head to remove the two screws on the upper headband plate.
    • Use a screwdriver with a T9 bit to remove one screw from the upper headband plate.
    • Remove the upper headband plate.
    • Repeat the past three steps for the upper headband plate on the other side.
  2. Astro A40 TR Plus Mixamp M80 Headband Replacement: passo 2, immagine 1 di 3 Astro A40 TR Plus Mixamp M80 Headband Replacement: passo 2, immagine 2 di 3 Astro A40 TR Plus Mixamp M80 Headband Replacement: passo 2, immagine 3 di 3
    • Use a screwdriver with a H2.0 head to remove the two screws on the lower headband plate.
    • Use a screwdriver with a T9 bit to remove one screw from the lower headband plate.
    • Remove the lower headband plate.
    • Repeat the past three steps for the lower headband plate on the other side.
  3. Astro A40 TR Plus Mixamp M80 Headband Replacement: passo 3, immagine 1 di 1
    • Use your hand to remove the headband adjuster.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 37
Tutti i Tempi: 2,830
