Salta al contenuto principale
Astro A40 TR External Headband Replacement
Cosa ti serve
  1. Astro A40 TR External Headband Replacement, External Headband: passo 1, immagine 1 di 2 Astro A40 TR External Headband Replacement, External Headband: passo 1, immagine 2 di 2
    • Remove two hex screws on each side to free and remove the base plate. Do each step for both sides.
  2. Astro A40 TR External Headband Replacement: passo 2, immagine 1 di 2 Astro A40 TR External Headband Replacement: passo 2, immagine 2 di 2
    • Pull apart earpiece assembly and the connecting headband piece.
  3. Astro A40 TR External Headband Replacement: passo 3, immagine 1 di 2 Astro A40 TR External Headband Replacement: passo 3, immagine 2 di 2
    • Gently pull the padding layer off of both ends using your hands.
  4. Astro A40 TR External Headband Replacement: passo 4, immagine 1 di 3 Astro A40 TR External Headband Replacement: passo 4, immagine 2 di 3 Astro A40 TR External Headband Replacement: passo 4, immagine 3 di 3
    • Locate the black wiring and gently pull it out of the plastic headpiece component.
Conclusione
Altre 2 persone hanno completato questa guida.
Mike
Membro da: 10/20/16
448 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 6-5, Martin Fall 2016 Membro di UMass Dartmouth, Team 6-5, Martin Fall 2016
UMASSD-MARTIN-F16S6G5
3 Membri
10 Guide realizzate
6 Commenti
Is there any place you can purchase a new external headband? The part that holds the foam piece in place broke on mine yesterday :(
zironyy - Replica
i dont have the screws i lost them when i dropped my headset
Sniping_Ninja10 - Replica
Did you buy screws? I need as well but I don’t know which one is good!
photo -
Where Can I buy screws for? I know the size is T8 but how long? which one is good for? Please help me
photo - Replica
where can i buy a new headband
Dewis Polonia - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 78
Tutti i Tempi: 13,617
