Salta al contenuto principale
Astro A40 Gen2 Speaker Replacement
Cosa ti serve
  1. Astro A40 Gen2 Speaker Replacement, Ear Pad: passo 1, immagine 1 di 2 Astro A40 Gen2 Speaker Replacement, Ear Pad: passo 1, immagine 2 di 2
    • Pull one corner of the pad to release it from the headset.
    • Pull the rest of the ear pad off.
  2. Astro A40 Gen2 Speaker Replacement, Speaker: passo 2, immagine 1 di 2 Astro A40 Gen2 Speaker Replacement, Speaker: passo 2, immagine 2 di 2
    • Locate the four 4.5 mm Philips #0 screws on the panel shown.
    • Remove them using a Phillips #0 head screwdriver.
    • Remove the panel.
  3. Astro A40 Gen2 Speaker Replacement: passo 3, immagine 1 di 2 Astro A40 Gen2 Speaker Replacement: passo 3, immagine 2 di 2
    • Using either your fingers or a plastic opening tool, pry off the speaker cover.
  4. Astro A40 Gen2 Speaker Replacement: passo 4, immagine 1 di 1
    • Locate the four 4.5 mm Philips #0 screws as shown on the speaker housing.
    • Remove the four screws using a Phillips #0 head screwdriver.
  5. Astro A40 Gen2 Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the housing to reveal the speaker.
    • Make sure not to break the small wire holding the two portions together.
Conclusione
Cal Poly, Team 20-18, Maness Winter 2015 Membro di Cal Poly, Team 20-18, Maness Winter 2015
CPSU-MANESS-W15S20G18
4 Membri
10 Guide realizzate
2 Commenti
Where do you buy the replacement speaker ? Thanks.
Steve Rosam - Replica
what speakers can these be replaced with? this guide is a little short on details about the actual removal and replacement of the speakers. the information here is just the start
Jasper W (Spike229) - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 4,462
