Salta al contenuto principale
Astak Mole Motherboard Replacement
Cosa ti serve
  1. Astak Mole Motherboard Replacement, Lower Case: passo 1, immagine 1 di 1
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the SD card.
  4. Astak Mole Motherboard Replacement: passo 4, immagine 1 di 1
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole Motherboard Replacement: passo 5, immagine 1 di 1
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 Astak Mole Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    • Sever the indicated adhesive connections to the motherboard allowing the wired connections to be removed.
    • All wired connections to the motherboard are removed by the thin plastic male connector inserted into the larger female plastic connection.
  7. Astak Mole Motherboard Replacement: passo 7, immagine 1 di 2 Astak Mole Motherboard Replacement: passo 7, immagine 2 di 2
    • The red wires may be adhered to the CPU as indicated and will need to be severed as shown.
    • Be careful not to scratch the CPU in this step. This is not a wired connection.
    • Sever the additional adhesive connections so that the wired connections may be removed.
  8. Astak Mole Motherboard Replacement: passo 8, immagine 1 di 1
    • Locate and unscrew the indicated screw using the (PH1) Phillips head bit.
    • Screw Measurements: (Length= 5.3mm)
  9. Astak Mole Motherboard Replacement: passo 9, immagine 1 di 2 Astak Mole Motherboard Replacement: passo 9, immagine 2 di 2
    • Remove the last two wired connections to the motherboard by severing the indicated connections.
    • Lift up the secondary motherboard as indicated using the metal spudger.
    • All connections should be severed from the motherboard and a new motherboard may be inserted.
    • It is advised to reapply adhesive to wired connections during reassembly.
Conclusione
Andrew Birch
Membro da: 09/15/16
204 Reputazione
2 Guide realizzate
USF Tampa, Team 2-2, Blackwell Fall 2016 Membro di USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 22
Tutti i Tempi: 491
