Salta al contenuto principale
Assembly of the Free Wheelchair Mission GEN 1
Cosa ti serve
  1. Assembly of the Free Wheelchair Mission GEN 1, Chair and Main Frame: passo 1, immagine 1 di 3 Assembly of the Free Wheelchair Mission GEN 1, Chair and Main Frame: passo 1, immagine 2 di 3 Assembly of the Free Wheelchair Mission GEN 1, Chair and Main Frame: passo 1, immagine 3 di 3
    • Fit the lawn chair with the main frame, aligning the back of the lawn chair with the main frame.
    • The chair should fit in easily.
    • Make sure the rear legs of the lawn chair are inside the frame . Also make sure the back of front legs line up with the holes on the front of the frame.
  2. Assembly of the Free Wheelchair Mission GEN 1, Front Frame and Castor Wheels: passo 2, immagine 1 di 3 Assembly of the Free Wheelchair Mission GEN 1, Front Frame and Castor Wheels: passo 2, immagine 2 di 3 Assembly of the Free Wheelchair Mission GEN 1, Front Frame and Castor Wheels: passo 2, immagine 3 di 3
    • Line up one of the castor wheels with the holes on the front legs of the wheelchair. Align the front frame with the castor wheels.
    • Make sure the guide knob on the castor wheel faces forward; the front frame must fit perfectly with the guide knob.
    • Insert one long bolt through the top-most hole connecting the front frame, castor wheel, lawn chair, and main frame.
    • Using pliers and the 10mm wrench, securely fasten a nut to the bolt and repeat on the other side.
  3. Assembly of the Free Wheelchair Mission GEN 1, Axel and Axel Plates: passo 3, immagine 1 di 3 Assembly of the Free Wheelchair Mission GEN 1, Axel and Axel Plates: passo 3, immagine 2 di 3 Assembly of the Free Wheelchair Mission GEN 1, Axel and Axel Plates: passo 3, immagine 3 di 3
    • Slide both of the axle plates onto the axle.
    • Position each of the plates on the inside of each of the lawn chair legs.
    • Attach both of the plates to the chair by screwing in two screws to each plate.
    • Use the pliers to hold the nut while screwing in the screw with a 10 mm wrench.
  4. Assembly of the Free Wheelchair Mission GEN 1, Rear Wheels: passo 4, immagine 1 di 3 Assembly of the Free Wheelchair Mission GEN 1, Rear Wheels: passo 4, immagine 2 di 3 Assembly of the Free Wheelchair Mission GEN 1, Rear Wheels: passo 4, immagine 3 di 3
    • Slide the 19 mm axle bolt into one of the rear wheels. Then hand-tighten the nut onto the bolt.
    • Insert the bolt into the axle so that the wheel is attached to the side of the frame.
    • Use the 19 mm crescent wrench to hold the nut in place. Then use the socket wrench (or multi-purpose tool) to screw the axle into the frame.
  5. Assembly of the Free Wheelchair Mission GEN 1, Brakes: passo 5, immagine 1 di 3 Assembly of the Free Wheelchair Mission GEN 1, Brakes: passo 5, immagine 2 di 3 Assembly of the Free Wheelchair Mission GEN 1, Brakes: passo 5, immagine 3 di 3
    • Locate the both of the brakes and the four long screws.
    • Place the brake behind the front frame right above the castor wheels
    • The brake with the yellow nob goes on the right side of the chair, and the brake with the black nob goes on the left.
    • Screw both of the screws into the bottom two holes in the frame using a 10 mm wrench to hold the nut . Then, use the T-Wrench to fasten the screws.
    • You can use a power drill instead of a T-Wrench to speed up the process.
  6. Assembly of the Free Wheelchair Mission GEN 1, Footrest: passo 6, immagine 1 di 3 Assembly of the Free Wheelchair Mission GEN 1, Footrest: passo 6, immagine 2 di 3 Assembly of the Free Wheelchair Mission GEN 1, Footrest: passo 6, immagine 3 di 3
    • Position the extendable footrest bar to the front frame, at the desired height.
    • Line up the two bolt holes on the footrest bar with the two holes on the front frame.
    • Pick the suitable position for the footrest that will complement the recipient (the position may be changed later).
    • Using the 10 mm wrench, secure the footrest bar to the front frame, using the a flat-head bolt and nut pointing in towards the center of the wheelchair.
    • Attach the footrest to the footrest bar, with the bottom of the footrest pointing upwards.
    • Match the footrest wedges up with the holes. Then attach the footrest to the front frame, using four small bolts. Next, tighten the four small nuts onto the bolts using the 10 mm wrench.
    • The heads of the bolts should fit perfectly through the footrest
  7. Assembly of the Free Wheelchair Mission GEN 1, Attach Cushion: passo 7, immagine 1 di 2 Assembly of the Free Wheelchair Mission GEN 1, Attach Cushion: passo 7, immagine 2 di 2
    • Place the cushion on top of the lawn chair seat. Then tie each of the four straps to the edge of the chair.
  8. Assembly of the Free Wheelchair Mission GEN 1, Hand Pump: passo 8, immagine 1 di 2 Assembly of the Free Wheelchair Mission GEN 1, Hand Pump: passo 8, immagine 2 di 2
    • Attach the hand pump to the back right side of the main frame, next to the right rear wheel. Do this using the final bolt and rounded nut.
    • Secure the hand pump to frame using the 10 mm wrench.
Conclusione
To disassemble your device, follow these instructions in reverse order, or look at our teardown guide. Free Wheelchair Mission GEN 1 Teardown
Erica Solum
Membro da: 04/19/13
48 Reputazione
1 Guida realizzata
Cal Poly, Team 14-7, Maness Spring 2013 Membro di Cal Poly, Team 14-7, Maness Spring 2013
CPSU-MANESS-S13S14G7
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,185
