Salta al contenuto principale
Assembling Parabolic Solar Cooker Tripod Base Stand
Cosa ti serve
  1. Assembling Parabolic Solar Cooker Tripod Base Stand, Assembling Parabolic Solar Cooker Tripod Base Stand: passo 1, immagine 1 di 2 Assembling Parabolic Solar Cooker Tripod Base Stand, Assembling Parabolic Solar Cooker Tripod Base Stand: passo 1, immagine 2 di 2
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
  2. Assembling Parabolic Solar Cooker Tripod Base Stand: passo 2, immagine 1 di 1
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
Conclusione
To disassemble your device, follow these instructions in reverse order.
Ashlie Reott
Membro da: 10/20/13
340 Reputazione
3 Guide realizzate
Cal Poly, Team 4-30, Amido Fall 2013 Membro di Cal Poly, Team 4-30, Amido Fall 2013
CPSU-AMIDO-F13S4G30
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 678
