Salta al contenuto principale
Arturia Microbrute Opening Procedure
Cosa ti serve
  1. Arturia Microbrute Opening Procedure, Arturia Microbrute Opening Procedure: passo 1, immagine 1 di 2 Arturia Microbrute Opening Procedure, Arturia Microbrute Opening Procedure: passo 1, immagine 2 di 2
    • Switch off the Microbrute and make sure to disconnect any cables.
    • Don’t forget the mini patch bay on the top right.
  2. Arturia Microbrute Opening Procedure: passo 2, immagine 1 di 1
    • Flip the Microbrute over and put it on a soft surface to not damage the knobs and faders.
    • Use a screwdriver to remove the twelve Philips screws on the bottom plate.
  3. Arturia Microbrute Opening Procedure: passo 3, immagine 1 di 3 Arturia Microbrute Opening Procedure: passo 3, immagine 2 di 3 Arturia Microbrute Opening Procedure: passo 3, immagine 3 di 3
    • Put the Microbrute on its front edge and carefully tilt open the bottom plate including the keyboard.
    • Be aware of the ribbon cable connecting the keyboard to the PCB.
    • The cable should give you enough slack to put the top section over the keyboard section for better handling.
  4. Arturia Microbrute Opening Procedure: passo 4, immagine 1 di 1
    • Next, focus on the connector of the keyboard.
  5. Arturia Microbrute Opening Procedure: passo 5, immagine 1 di 3 Arturia Microbrute Opening Procedure: passo 5, immagine 2 di 3 Arturia Microbrute Opening Procedure: passo 5, immagine 3 di 3
    • Use a spudger to unlock the connector by pushing both left and right locking tabs tabs towards the cable.
  6. Arturia Microbrute Opening Procedure: passo 6, immagine 1 di 2 Arturia Microbrute Opening Procedure: passo 6, immagine 2 di 2
    • Grab the ribbon cable with your fingers and pull it out of the connector.
  7. Arturia Microbrute Opening Procedure: passo 7, immagine 1 di 1
    • Now the Microbrute is open and the bottom plate with the keyboard is separated from the rest of the device.
Conclusione
Tobias Isakeit
Membro da: 03/31/14
129.557 Reputazione
189 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 307
