Salta al contenuto principale
Arnova 7K G3 Rubber Feet Replacement
Cosa ti serve
  1. Arnova 7K G3 Rubber Feet Replacement, Rear Cover: passo 1, immagine 1 di 3 Arnova 7K G3 Rubber Feet Replacement, Rear Cover: passo 1, immagine 2 di 3 Arnova 7K G3 Rubber Feet Replacement, Rear Cover: passo 1, immagine 3 di 3
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Arnova 7K G3 Rubber Feet Replacement: passo 2, immagine 1 di 2 Arnova 7K G3 Rubber Feet Replacement: passo 2, immagine 2 di 2
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Arnova 7K G3 Rubber Feet Replacement: passo 3, immagine 1 di 1
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Arnova 7K G3 Rubber Feet Replacement, Rubber Feet: passo 4, immagine 1 di 2 Arnova 7K G3 Rubber Feet Replacement, Rubber Feet: passo 4, immagine 2 di 2
    • Locate the two lower bumpers on the back cover. These are the rubber feet.
    • Flip the cover over to reveal the inside.
    • Locate the two rubber tabs, there are two for each rubber foot. They are located on the inside of the cover.
  5. Arnova 7K G3 Rubber Feet Replacement: passo 5, immagine 1 di 1
    • Push the two tabs on each foot down using the pointed end of a spudger.
    • It may take some force to push in the tabs. Prying with the pointed end of the spudger and wiggling the tab free may be necessary.
  6. Arnova 7K G3 Rubber Feet Replacement: passo 6, immagine 1 di 1
    • Flip the cover back over so you see the outside. Remove the rubber feet if they have not already fallen out.
Conclusione
To reassemble your device, follow these instructions in reverse order with the new rubber feet.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 197
