Salta al contenuto principale
ArmorAll AA255 Motor Replacement
Cosa ti serve
  1. ArmorAll AA255 Motor Replacement, Lower Motor Housing: passo 1, immagine 1 di 1
    • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
  2. ArmorAll AA255 Motor Replacement: passo 2, immagine 1 di 1
    • Remove the five 15mm PH2 screws.
  3. ArmorAll AA255 Motor Replacement: passo 3, immagine 1 di 1
    • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
  4. ArmorAll AA255 Motor Replacement: passo 4, immagine 1 di 2 ArmorAll AA255 Motor Replacement: passo 4, immagine 2 di 2
    • Gently separate the upper and lower sections of the main housing.
  5. ArmorAll AA255 Motor Replacement, Motor: passo 5, immagine 1 di 3 ArmorAll AA255 Motor Replacement, Motor: passo 5, immagine 2 di 3 ArmorAll AA255 Motor Replacement, Motor: passo 5, immagine 3 di 3
    • Use a PH2 screwdriver to remove the five 15mm screws on the ball cage under the main housing.
    • Pull the ball cage to remove it from the main housing.
  6. ArmorAll AA255 Motor Replacement: passo 6, immagine 1 di 3 ArmorAll AA255 Motor Replacement: passo 6, immagine 2 di 3 ArmorAll AA255 Motor Replacement: passo 6, immagine 3 di 3
    • Remove one 13mm nut from the main housing.
    • The metal ring under the nut has sharp edges. You may need to use a tool such as pliers to prevent injury.
    • Remove metal ring from the main housing.
    • Use a PH2 screwdriver to remove the four 12mm screws from the main housing.
  7. ArmorAll AA255 Motor Replacement: passo 7, immagine 1 di 3 ArmorAll AA255 Motor Replacement: passo 7, immagine 2 di 3 ArmorAll AA255 Motor Replacement: passo 7, immagine 3 di 3
    • Turn the whole body over to separate motor cover.
    • Use a PH2 screwdriver to remove the five 15mm screw.
    • Remove the white power wire from the motor cover.
    • Pull the motor cover from the main housing.
  8. ArmorAll AA255 Motor Replacement: passo 8, immagine 1 di 2 ArmorAll AA255 Motor Replacement: passo 8, immagine 2 di 2
    • Use a plastic opening tool to remove two cables from the motor. One white cable is from the power cord, and one black cable is from the switch.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • You may need to mark the color of the wire on each terminal for reassembly.
  9. ArmorAll AA255 Motor Replacement: passo 9, immagine 1 di 2 ArmorAll AA255 Motor Replacement: passo 9, immagine 2 di 2
    • The motor is ready for replacement. Pull the motor to separate.
Conclusione
Altre 6 persone hanno completato questa guida.
YeaJun Yoo
Membro da: 02/11/16
302 Reputazione
1 Guida realizzata
IUPUI, Team 2-1, Baechle Spring 2016 Membro di IUPUI, Team 2-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G1
4 Membri
4 Guide realizzate
4 Commenti
What is the motor product no? It will help if there is a link to buy the motor
Austin K - Replica
Medida de los carboncitos que lleva el motor?
SERVANDO ARTEA FAVELA - Replica
Buenas nochew necesito saber si existe a la venta la hélice o ventiladora que hace la succión de la aspiradora. Porfavor alguien puede ayudarme dejo mi correo erikazavala2882@gmail.com desde Honduras.
erikazavala2882 - Replica
Part #for motor ???? Mine just the carbon brush is worn. Need replacement part # for motor or brushes ????
A Anderson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 66
Tutti i Tempi: 4,105
