Cosa ti serve
Pick a location that is by the band so that if you make any scratches they will be less obvious when you are done. Place the screwdriver between the frame and the back cover. Gently tap the back of the screwdriver with a small hammer or whatever you have around. Do not use your hand!
While securing the inside of the watch with a finger or thumb, gently pry out the battery.
Insert a new battery. Line up the cover in the correct position. Keep the notch lined up with the winding screw. Secure the back to the frame by applying equal pressure and squeezing the two parts together.
Altre 2 persone hanno completato questa guida.
1Commento della guida
Ser magkanu po ang base metal vezel stailess steel v353-6AOO RO magkanu po model naganyan
