Salta al contenuto principale
Archos Jukebox Recorder 20 Hard Drive Replacement
Cosa ti serve
  1. Archos Jukebox Recorder 20 Hard Drive  Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 2, immagine 1 di 1
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
  3. Archos Jukebox Recorder 20 Hard Drive  Replacement, Hard Drive: passo 3, immagine 1 di 2 Archos Jukebox Recorder 20 Hard Drive  Replacement, Hard Drive: passo 3, immagine 2 di 2
    • Use the T10 Torx Screwdriver to remove the 2 torx screws on each side of the device.
    • Two on each side for a total of four.
  4. Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 4, immagine 1 di 2 Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 4, immagine 2 di 2
    • Remove the 2 screws on the top and the 2 screws on the bottom of the device using a Phillips #0 screwdriver.
  5. Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 5, immagine 1 di 1
    • Remove the outer metal casing of the device by popping it off with a plastic opening tool.
  6. Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 6, immagine 1 di 1
    • Remove the rubber bumpers on all four corners of the device.
  7. Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 7, immagine 1 di 2 Archos Jukebox Recorder 20 Hard Drive  Replacement: passo 7, immagine 2 di 2
    • Lift the hard drive out of its casing with the help of a plastic opening tool and slide it out. This will disconnect the pins connecting the drive to the rest of the device.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team S1-G4, Freund Spring 2018 Membro di IUPUI, Team S1-G4, Freund Spring 2018
IUPUI-FREUND-S18S1G4
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,297
