Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Introduzione
This guide will show you how to replace the front button panel.
Parti
Nessuna parte specificata.
  1. Remove the plastic cover over the batteries on both sides of the device.
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
  3. Using the Philips Screwdriver, remove the top 2 screws.
    • Using the Philips Screwdriver, remove the top 2 screws.
    • The screws are very small (2.5mm), put them somewhere you won't lose them.
  4. Using the Philips screwdriver, remove the bottom 2 screws (2.5mm).
    • Using the Philips screwdriver, remove the bottom 2 screws (2.5mm).
  5. Remove the face. Remove the face.
    • Remove the face.
Conclusione
Bryant Bucci
Membro da: 21/03/2018
97 Reputazione
1 Guida realizzata
IUPUI, Team S2-G3, Freund Spring 2018 Membro di IUPUI, Team S2-G3, Freund Spring 2018
IUPUI-FREUND-S18S2G3
3 Membri
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 92
