Salta al contenuto principale
Archos 97 Carbon Display Screen Replacement
Cosa ti serve
  1. Archos 97 Carbon Display Screen Replacement, Removing the old cover from tablet: passo 1, immagine 1 di 2 Archos 97 Carbon Display Screen Replacement, Removing the old cover from tablet: passo 1, immagine 2 di 2
    • Lay your tablet upwards facing you.
    • Using the opening tool, begin by prying the tablet starting in the top left corner. This can be found near the volume and power buttons.
    • Begin to work your way around the tablet in a clockwise motion to separate the screen from the cover.
  2. Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: passo 2, immagine 1 di 3 Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: passo 2, immagine 2 di 3 Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: passo 2, immagine 3 di 3
    • Once you have opened the screen, you will see two cables that connect the screen and the interior of the tablet.
    • Remove the white tab located on the right side of the interior by removing the tape and plug that connects it to the tab.
  3. Archos 97 Carbon Display Screen Replacement, Removing the black tape from the tablet: passo 3, immagine 1 di 2 Archos 97 Carbon Display Screen Replacement, Removing the black tape from the tablet: passo 3, immagine 2 di 2
    • On the left side of the tablet, you will see a silver cable connecting the screen to the motherboard.
    • Using the tweezers, remove the black tape that is connecting the cable and screen. This will allow the gold connector to come loose.
    • The screen should be separated from the tablet.
  4. Archos 97 Carbon Display Screen Replacement, Removing the screws: passo 4, immagine 1 di 2 Archos 97 Carbon Display Screen Replacement, Removing the screws: passo 4, immagine 2 di 2
    • Remove the screws on the backside of the screen using a screwdriver.
    • There are four screws; one is covered by tape.
  5. Archos 97 Carbon Display Screen Replacement, Removing screen from frame: passo 5, immagine 1 di 3 Archos 97 Carbon Display Screen Replacement, Removing screen from frame: passo 5, immagine 2 di 3 Archos 97 Carbon Display Screen Replacement, Removing screen from frame: passo 5, immagine 3 di 3
    • Gently pry the screen from the black frame that surrounds it using the opening tool.
    • Work in a clockwise motion until the screen is detached from the frame.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Hi,
Is this similar to replacing the touch screen on the Archos 101B model?.
colin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,578
