Salta al contenuto principale
Archos 97 Carbon Battery Replacement
Cosa ti serve
  1. Archos 97 Carbon Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Pry open the tablet by having the tablet face upward. To pry open, start over in the left corner (by the buttons) working clockwise until the tablet is open.
  2. Archos 97 Carbon Battery Replacement: passo 2, immagine 1 di 2 Archos 97 Carbon Battery Replacement: passo 2, immagine 2 di 2
    • Once the screen is separated from the back panel, you will see two cables connecting the screen to the interior of the tablet (one silver, one black)
    • Remove the black tape that is holding the end of the black cable to the white tab.
    • Gently pull the cable away from the tab with tweezers disconnecting the plug from the outlet.
  3. Archos 97 Carbon Battery Replacement: passo 3, immagine 1 di 1
    • Remove the silver cable by removing the tape that connects the cable and screen. Gently detach the gold cable from the outlet.
  4. Archos 97 Carbon Battery Replacement: passo 4, immagine 1 di 2 Archos 97 Carbon Battery Replacement: passo 4, immagine 2 di 2
    • Now the interior of the tablet is fully accessible.
    • Heat the soldering gun until it is fully heated. Place the tip of the soldering gun over the solder that seals the red and black battery cables to the motherboard. Once the solder is heated the cables can be removed.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 3,818
