Salta al contenuto principale
Aquaris M5 back Cover Replacement
Cosa ti serve
  1. Aquaris M5 back Cover Replacement, Back Cover: passo 1, immagine 1 di 2 Aquaris M5 back Cover Replacement, Back Cover: passo 1, immagine 2 di 2
    • Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
    • Between the 2 SIM card slots is a good place to start.
    • Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
  2. Aquaris M5 back Cover Replacement: passo 2, immagine 1 di 2 Aquaris M5 back Cover Replacement: passo 2, immagine 2 di 2
    • Slide the opening tool back to the top of the phone, to disconnect all the clips on the edge.
    • Slide around the corner and along the top edge, to also disconnect these clips.
  3. Aquaris M5 back Cover Replacement: passo 3, immagine 1 di 3 Aquaris M5 back Cover Replacement: passo 3, immagine 2 di 3 Aquaris M5 back Cover Replacement: passo 3, immagine 3 di 3
    • Be careful not to bend the back cover too hard to prevent some of the clips breaking.
    • Grab the back cover by the loosened edge.
    • Gently bend and twist the flexible back cover a bit to disconnect the remaining clips.
    • Take off the back cover.
Conclusione
Theo Mat
Membro da: 11/12/17
12.782 Reputazione
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 852
