Salta al contenuto principale
Aquaris M5 Rear Camera Replacement
Cosa ti serve
  1. Aquaris M5 Rear Camera Replacement, Back Cover: passo 1, immagine 1 di 2 Aquaris M5 Rear Camera Replacement, Back Cover: passo 1, immagine 2 di 2
    • Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
    • Between the 2 SIM card slots is a good place to start.
    • Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
  2. Aquaris M5 Rear Camera Replacement: passo 2, immagine 1 di 2 Aquaris M5 Rear Camera Replacement: passo 2, immagine 2 di 2
    • Slide the opening tool back to the top of the phone, to disconnect all the clips on the edge.
    • Slide around the corner and along the top edge, to also disconnect these clips.
  3. Aquaris M5 Rear Camera Replacement: passo 3, immagine 1 di 3 Aquaris M5 Rear Camera Replacement: passo 3, immagine 2 di 3 Aquaris M5 Rear Camera Replacement: passo 3, immagine 3 di 3
    • Be careful not to bend the back cover too hard to prevent some of the clips breaking.
    • Grab the back cover by the loosened edge.
    • Gently bend and twist the flexible back cover a bit to disconnect the remaining clips.
    • Take off the back cover.
  4. Aquaris M5 Rear Camera Replacement, Battery: passo 4, immagine 1 di 1
    • Damaging the liquid indicator sticker, on the middle most screw, will void the warranty of the phone.
    • Unscrew the ten black 4mm Phillips #00 Screws from the mainboard shield.
    • Unscrew the golden 3.4mm Phillips #00 screw on the middle-right side of the mainboard shield.
  5. Aquaris M5 Rear Camera Replacement: passo 5, immagine 1 di 3 Aquaris M5 Rear Camera Replacement: passo 5, immagine 2 di 3 Aquaris M5 Rear Camera Replacement: passo 5, immagine 3 di 3
    • Insert the flat side of a spudger between the mainboard shield and the frame of the phone.
    • Twist the spudger to lift up the mainboard shield.
    • Remove the mainboard shield from the phone.
  6. Aquaris M5 Rear Camera Replacement: passo 6, immagine 1 di 2 Aquaris M5 Rear Camera Replacement: passo 6, immagine 2 di 2
    • Use a spudger to disconnect the battery's flex cable from the mainboard.
    • Pull of the sticker on the bottom side of the battery.
    • Grab the sticker and lift it up to take the battery out of the phone.
  7. Aquaris M5 Rear Camera Replacement, Rear Camera: passo 7, immagine 1 di 2 Aquaris M5 Rear Camera Replacement, Rear Camera: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the flat side of a spudger to disconnect the camera's flex cable.
    • Use Tweezers to grab the camera and lift it out of the phone.
Conclusione
Theo Mat
Membro da: 11/12/17
12.790 Reputazione
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 312
