Salta al contenuto principale
Introduzione
Use this guide to replace the loud speaker in your bq Aquaris M5.
  1. Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone. Between the 2 SIM card slots is a good place to start.
    • Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
    • Between the 2 SIM card slots is a good place to start.
    • Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
  2. Slide the opening tool back to the top of the phone, to disconnect all the clips on the edge. Slide around the corner and along the top edge, to also disconnect these clips.
    • Slide the opening tool back to the top of the phone, to disconnect all the clips on the edge.
    • Slide around the corner and along the top edge, to also disconnect these clips.
  3. Be careful not to bend the back cover too hard to prevent some of the clips breaking. Grab the back cover by the loosened edge. Gently bend and twist the flexible back cover a bit to disconnect the remaining clips.
    • Be careful not to bend the back cover too hard to prevent some of the clips breaking.
    • Grab the back cover by the loosened edge.
    • Gently bend and twist the flexible back cover a bit to disconnect the remaining clips.
    • Take off the back cover.
  4. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  5. Damaging the liquid indicator sticker, on the middle most screw, will void the warranty of the phone.
    • Damaging the liquid indicator sticker, on the middle most screw, will void the warranty of the phone.
    • Unscrew the ten black 4mm Phillips #00 Screws from the mainboard shield.
    • Unscrew the golden 3.4mm Phillips #00 screw on the middle-right side of the mainboard shield.
  6. Insert the flat side of a spudger between the mainboard shield and the frame of the phone. Twist the spudger to lift up the mainboard shield. Remove the mainboard shield from the phone.
    • Insert the flat side of a spudger between the mainboard shield and the frame of the phone.
    • Twist the spudger to lift up the mainboard shield.
    • Remove the mainboard shield from the phone.
  7. Use a spudger to disconnect the battery's flex cable from the mainboard. Pull of the sticker on the bottom side of the battery.
    • Use a spudger to disconnect the battery's flex cable from the mainboard.
    • Pull of the sticker on the bottom side of the battery.
    • Grab the sticker and lift it up to take the battery out of the phone.
  8. Take out the seven 4mm Phillips #00 screws, holding the loud speaker unit to the mid frame of the phone.
    • Take out the seven 4mm Phillips #00 screws, holding the loud speaker unit to the mid frame of the phone.
  9. Insert the flat side of a spudger into the gap on the right side of the loud speaker. Lever the loud speaker up with the spudger.
    • Insert the flat side of a spudger into the gap on the right side of the loud speaker.
    • Lever the loud speaker up with the spudger.
    • Grab the loud speaker and take it out of the phone.
Conclusione
Theo Mat
Membro da: 12/11/2017
10.662 Reputazione
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
Tutti i Tempi: 240
