Introduzione
This guide details how to replace the power supply of the Apple iPod Hi-Fi speaker system.
Cosa ti serve
Take one spudger and fit it under the grille.
Use your first spudger to pry up and make room to insert a second one.
Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
Use the other spudger to raise the grille, allowing you to see where you're working.
Antes de poner de vuelta la placa de aluminio con el mismo secador de aire caliente puedes calentar los restos de pegamento adherido y lo montas . Pones la rejilla de tela en su lugar y lo dejas una hora apoyado con la parte trasera mirando hacia arriba.asi el pegamento recalentado y con la presiĂ³n del peso del aparato harĂ¡ que se adhiera.
Remove all eight 3.3mm JIS #1 screws holding the front panel in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
Remove the four 3.3mm JIS #1 screws holding the large speaker in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
Place the speaker on its back with the dock facing away from you.
Unplug the 2 cables on the top of the power supply box.
Unclip the cables clipped together to the left of the power supply box.
Altre 6 persone hanno completato questa guida.
6 Commenti
It not just the power supply. The amplifier board is attached to the top.
Where can we find a compatible power suply? Thank you.
Bonjour le tutoriel est très bien mais ou peut-on acheter le bloc d’alimentation ?
Merci
where can i find a power supply please .
What is the Part Number of the Apple iPod Hi-Fi internal Power Supply and Amplifier Assembly?
liteon PA-3150-01A 30w DC
BUSINESS -
