Salta al contenuto principale
Apple XServe Raid Battery Replacement
Cosa ti serve
  1. Apple XServe Raid Battery Replacement, Raid Battery: passo 1, immagine 1 di 2 Apple XServe Raid Battery Replacement, Raid Battery: passo 1, immagine 2 di 2
    • Remove the drive module(s) from the front of the Xserve.
    • Depending on configuration, there may be up to three modules.
  2. Apple XServe Raid Battery Replacement: passo 2, immagine 1 di 1
    • Remove the power supplies from the system by pulling on the built-in removal bar.
    • Depending on configuration, there may only be one power supply unit.
  3. Apple XServe Raid Battery Replacement: passo 3, immagine 1 di 1
    • Remove the top cover of the system by loosening the two thumb screws located on the back panel.
    • Discharge any static electricity by touching a grounded surface. Failure to do so may cause damage to the internal components.
  4. Apple XServe Raid Battery Replacement: passo 4, immagine 1 di 3 Apple XServe Raid Battery Replacement: passo 4, immagine 2 di 3 Apple XServe Raid Battery Replacement: passo 4, immagine 3 di 3
    • Remove the fan module by loosening the two Phillips #0 screws located on each side of the module.
  5. Apple XServe Raid Battery Replacement: passo 5, immagine 1 di 1
    • Disconnect the raid battery connector using a plastic spudger.
  6. Apple XServe Raid Battery Replacement: passo 6, immagine 1 di 2 Apple XServe Raid Battery Replacement: passo 6, immagine 2 di 2
    • Remove the SAS backplane power cable by pulling the cable out of the board.
    • Remove the data cable from the board using a spudger to lift the connector out of the socket.
    • Loosen the Phillips #0 screw holding the backplane in the system.
    • To remove the backplane from the chassis, slide the board down, tilt it to a 45 degree angle, and pull the board out.
  7. Apple XServe Raid Battery Replacement: passo 7, immagine 1 di 1
    • Loosen the single Phillips #0 screw on the power backplane.
    • Slide the backplane out of the connector on the main board, and lift it straight out.
  8. Apple XServe Raid Battery Replacement: passo 8, immagine 1 di 1
    • Lift the raid card battery out of the chassis.
Conclusione
Altre 2 persone hanno completato questa guida.
Cody West
Membro da: 10/20/20
234 Reputazione
1 Guida realizzata
Texas Tech, Team S14-G2, Cowan Fall 2020 Membro di Texas Tech, Team S14-G2, Cowan Fall 2020
TTU-COWAN-F20S14G2
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 720
