Salta al contenuto principale
Apple Wireless Keyboard Logic Board Replacement
Cosa ti serve
  1. Apple Wireless Keyboard Logic Board Replacement, Logic Board: passo 1, immagine 1 di 2 Apple Wireless Keyboard Logic Board Replacement, Logic Board: passo 1, immagine 2 di 2
    • Insert a metal spudger to open the plastic part under the Keyboard
  2. Apple Wireless Keyboard Logic Board Replacement: passo 2, immagine 1 di 1
    • Remove the screw
  3. Apple Wireless Keyboard Logic Board Replacement: passo 3, immagine 1 di 3 Apple Wireless Keyboard Logic Board Replacement: passo 3, immagine 2 di 3 Apple Wireless Keyboard Logic Board Replacement: passo 3, immagine 3 di 3
    • Pull the lock up and disconnect the connection cable
  4. Apple Wireless Keyboard Logic Board Replacement: passo 4, immagine 1 di 1
    • Keeping the connection cable, push out the logic board's placement
  5. Apple Wireless Keyboard Logic Board Replacement: passo 5, immagine 1 di 1
    • Unlock the latch of the logic board
  6. Apple Wireless Keyboard Logic Board Replacement: passo 6, immagine 1 di 1
    • Remove the logic board from the placement
Conclusione
Altre 20 persone hanno completato questa guida.
Nicola
Membro da: 11/14/13
638 Reputazione
1 Guida realizzata
9Commenti sulla guida
Hi, anyone know where its possible to buy this logic board? My bluetooth chip is apparently broken
steve - Replica
Which model of keyboard is this, because my A1255 doesn't disassemble like this - the battery terminal is solidly restrained inside the tube by means of a metal expansion ring. Doesn't seem user repairable :(
gordon jackson - Replica
My power button was stuck. The shell was dented. This was an easier way to access and remove the button so I was able to file the inside of the tube smooth so the button would move freely.
Tony - Replica
I have disassembled my keyboard as shown above, but now I need a replacement Wireless Keyboard Logic Board. I have not been able to find one. Any suggestions?
Martin Rubio - Replica
Very nice! in my case the flat cable was not properly connecting. I only found out when i opened the cap to the logic board and saw the cable sitting slanted in its connector. Put it back straight and now it works again. Cheers!!
mollymol - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 100
Tutti i Tempi: 50,059
