Salta al contenuto principale
Apple Watch Series 6 Battery Replacement
Cosa ti serve
  1. Apple Watch Series 6 Battery Replacement, Power down the watch: passo 1, immagine 1 di 2 Apple Watch Series 6 Battery Replacement, Power down the watch: passo 1, immagine 2 di 2
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Attach or remove the watch band as needed to provide more control as you make repairs.
  2. Apple Watch Series 6 Battery Replacement, Soften the display adhesive: passo 3, immagine 1 di 1
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
    • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
  3. Apple Watch Series 6 Battery Replacement, Display opening: passo 4, immagine 1 di 3 Apple Watch Series 6 Battery Replacement, Display opening: passo 4, immagine 2 di 3 Apple Watch Series 6 Battery Replacement, Display opening: passo 4, immagine 3 di 3
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, most distant to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
  4. Apple Watch Series 6 Battery Replacement: passo 5, immagine 1 di 3 Apple Watch Series 6 Battery Replacement: passo 5, immagine 2 di 3 Apple Watch Series 6 Battery Replacement: passo 5, immagine 3 di 3
    • Insert an opening pick in the gap your created.
    • Slide the opening pick along the short edge of the watch to cut the adhesive.
  5. Apple Watch Series 6 Battery Replacement: passo 6, immagine 1 di 2 Apple Watch Series 6 Battery Replacement: passo 6, immagine 2 di 2
    • Slide the opening pick around the corner and along the long edge on the opposite side of the watch crown to cut the display adhesive.
  6. Apple Watch Series 6 Battery Replacement: passo 7, immagine 1 di 2 Apple Watch Series 6 Battery Replacement: passo 7, immagine 2 di 2
    • Slide the opening pick around the corner to cut the remaining adhesive on the short edge of the watch next to the watch crown.
  7. Apple Watch Series 6 Battery Replacement: passo 8, immagine 1 di 2 Apple Watch Series 6 Battery Replacement: passo 8, immagine 2 di 2
    • Place the watch on a flat surface and use an opening pick to slice through any remaining adhesive.
    • Try not to slice near the watch crown to prevent damaging the display cables. If you must slice near the crown, don't insert the opening pick deeper than 1/16th of an inch (~2 mm).
    • Slide an opening pick under the opposite display edge of the watch crown.
    • Twist the opening pick to loosen the display off the watch case.
    • Don't try to remove the display. It is still connected to the watch assembly.
  8. Apple Watch Series 6 Battery Replacement: passo 9, immagine 1 di 3 Apple Watch Series 6 Battery Replacement: passo 9, immagine 2 di 3 Apple Watch Series 6 Battery Replacement: passo 9, immagine 3 di 3
    • Be careful not to strain the display cables when you fold the display to the side.
    • Lift the display and carefully pull it towards the watch crown.
    • Swing the display open to an upward position.
  9. Apple Watch Series 6 Battery Replacement, Soften the battery adhesive: passo 10, immagine 1 di 1
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the rear side of the watch to loosen the battery adhesive. Leave the iOpener on the watch for at least two minutes.
  10. Apple Watch Series 6 Battery Replacement, Determine which procedure to follow: passo 11, immagine 1 di 1
    • From this point, the battery removal procedure for the 40 mm watch differs slightly from the 44 mm version.
    • If you're replacing the battery for a 40 mm watch, continue with this step.
    • If you're replacing the battery for a 44 mm watch, continue with this step.
  11. Apple Watch Series 6 Battery Replacement, Pry up the battery: passo 12, immagine 1 di 3 Apple Watch Series 6 Battery Replacement, Pry up the battery: passo 12, immagine 2 di 3 Apple Watch Series 6 Battery Replacement, Pry up the battery: passo 12, immagine 3 di 3
    • The following four steps show how to remove the battery from a 40 mm Apple Watch Series 6.
    • Insert an opening pick between the battery and the Taptic Engine.
    • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the mainboard.
    • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
    • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
  12. Apple Watch Series 6 Battery Replacement, Move the battery: passo 13, immagine 1 di 3 Apple Watch Series 6 Battery Replacement, Move the battery: passo 13, immagine 2 di 3 Apple Watch Series 6 Battery Replacement, Move the battery: passo 13, immagine 3 di 3
    • The battery flex cable is long enough to allow you to place the battery outside the watch case, but avoid straining the cable when you lift the battery out of its recess.
    • Carefully lift and swing the battery out of its recess.
  13. Apple Watch Series 6 Battery Replacement, Disconnect the battery: passo 14, immagine 1 di 2 Apple Watch Series 6 Battery Replacement, Disconnect the battery: passo 14, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the battery connector.
    • Remove the battery.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you're reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly.
    • Alternatively, remove the old adhesive with high concentration isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
  14. Apple Watch Series 6 Battery Replacement, Pry up the battery: passo 16, immagine 1 di 3 Apple Watch Series 6 Battery Replacement, Pry up the battery: passo 16, immagine 2 di 3 Apple Watch Series 6 Battery Replacement, Pry up the battery: passo 16, immagine 3 di 3
    • The following four steps show how to remove the battery from a 44 mm Apple Watch Series 6.
  15. Apple Watch Series 6 Battery Replacement, Move the battery: passo 17, immagine 1 di 3 Apple Watch Series 6 Battery Replacement, Move the battery: passo 17, immagine 2 di 3 Apple Watch Series 6 Battery Replacement, Move the battery: passo 17, immagine 3 di 3
    • The battery flex cable is long enough to place the battery outside the watch case during the following procedure but avoid straining it when lifting the battery out of its recess.
    • Carefully lift the battery out of its recess and place it outside the watch case opposite to the Taptic Engine.
  16. Apple Watch Series 6 Battery Replacement, Remove the battery connector screw: passo 18, immagine 1 di 1
    • Remove the single 1.2 mm-long tri point Y000 screw.
  17. Apple Watch Series 6 Battery Replacement: passo 19, immagine 1 di 2 Apple Watch Series 6 Battery Replacement: passo 19, immagine 2 di 2
    • Use a pair of tweezers to remove the metal shield covering the battery connector.
  18. Apple Watch Series 6 Battery Replacement: passo 20, immagine 1 di 2 Apple Watch Series 6 Battery Replacement: passo 20, immagine 2 di 2
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly.
Conclusione
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your Apple Watch Series 6, follow these instructions in reverse order. Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
For optimal performance, calibrate your newly installed battery after completing this guide.
Altre 2 persone hanno completato questa guida.
iFixit Membro di iFixit
Community
137 Membri
17.047 Guide realizzate
2 Commenti
Where do I purchase a replacement battery?
Salma Khan - Replica
Moin Team !
Welches Klebeband benötige um das Display möglichst Wasserresistent abzudichten und festzukleben ?
ike-bhv - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 50
Ultimi 7 Giorni: 499
Ultimi 30 Giorni: 2,450
Tutti i Tempi: 31,580
