Introduzione
Use this guide to repair a damaged Apple Watch Series 2/3 screen.
- Update Apple Watch to avoid pairing issues after refurbishing procedure.
*Refurbishing your screen may cause issues with Apple Pay. If possible, to reduce the chance of problems, delete all Apple Pay account information before the procedure, and after the procedure, enter the information again.
- This guide shows the procedure on the standard (GPS) version of the smartwatch.
Cosa ti serve
Before starting the procedure, remove the device from the charger and turn it off.
Press and hold the two side buttons.
When the Apple logo appears, release the circular button and hold down the other button.
When the Apple logo disappears, release the other button. The Apple Watch will be turned off.
Place the Apple Watch screen in contact with the heating plate at 100°C for 1 min, in order to soften the glue that holds the screen to the frame.
Pour alcohol all over the edge of the screen. Place the blade in the thin space between the edge of the screen and the frame.
Press firmly down, tilting the blade in the direction of removal from the screen.
Do not put the spudger blade more than 2mm in the device, doing this could tear the "Force Touch."
Use isopropyl alcohol to peel off the tape covering the flex cables and connectors from the screen.
Use a plastic lever (crowbar) to unlock the first of the three ZIF connectors by lifting the small locking tab opposite the flex cable.
Lift the locking tabs on the two remaining ZIF connectors.
Use tweezers to disconnect the flexible cables from the screen by gently pulling them apart and remove the screen
Place the Apple Watch screen in contact with the hot plate at 100°C for 2 min, in order to heat the glass.
Hold the middle of the display and using a pliers or nail pliers, cut the curved edges. Initially on the sides, then on the top and bottom.
After removing the edges, apply an adhesive tape on the display, and put it in the separator at 100°C.
With tweezers or a thin metal spudger, remove the grounding using isopropyl alcohol.
Using a metal spudger and isopropyl alcohol, lift the touch flex (middle flex).
Turn on the separator vacuum until the screen is fixed to the surface.
Enter the 0.4mm thick molybdenum/steel/gold line between the touchscreen and the OLED display of the Apple Watch screen.
Cautiously make sawing motions at the same level/plane as the glass.
First of all check if there are glass shards on the display. In case of positive, use isopropyl alcohol and the "protective film of the OCA" in order to remove the shards.
After cleaning the glasses, put the display on a hard surface and remove the glue using a grinding machine.
Use isopropyl alcohol in order to remove the remainder of OCA glue, other impurities and grease.
Apply the OCA glue in the direction of the display flex wire.
Remove the OCA protection and put the display in the application cast.
Apply the touch glass on the application cast.
Hold the cast with one hand and place with the other hand the index finger below the screen and the thumb above the screen. Close and remove the screen from the cast.
Put the screen on the lamination rubber and close the lamination top.
Laminate 2 minutes at 40°C.
Use isopropyl alcohol and metal tweezers in order to remove the shards along all the edge.
Use isopropyl alcohol and cotton swab in order to clean along all the edge, removing the thin film of glue that envelops the edge above the force touch.
Use "mouse tooth" twezzers in order to remove carefully the replacement adhesive with the blue protective film from the supporting role.
Align the adhesive in the frame .
Place the replcamente adhesive on the top of the force touch and use the plastic pointy end in order to move and press the adhesive.
Place the flex wires on the ZIF connectors and plug them with the help of "mouse tooth" twezzers, guide the wires into the connectors.
After connecting, close the drawers.
Turn the device on and make the tests.
Remove the protective film of the adhesive that covers the force touch.
Place and press the screen onto the adhesive in the edge.
Put the device for 2 minutes in the autoclave.
Load the device and make the final cleaning with lens cleaner.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
