Salta al contenuto principale
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Apple Watch SE, usa il nostro manuale di assistenza.
  1. Apple Watch SE Mother Board Removal, Removing the Taptic Engine: passo 1, immagine 1 di 2 Apple Watch SE Mother Board Removal, Removing the Taptic Engine: passo 1, immagine 2 di 2
    • Unscrew Tri-screw and remove small plate cover.
    • Then, remove these two Tri-screws.
  2. Apple Watch SE Mother Board Removal, Removing the Taptic Engine pt. 2: passo 2, immagine 1 di 3 Apple Watch SE Mother Board Removal, Removing the Taptic Engine pt. 2: passo 2, immagine 2 di 3 Apple Watch SE Mother Board Removal, Removing the Taptic Engine pt. 2: passo 2, immagine 3 di 3
    • Undo both connectors highlighted.
    • Then the Taptic engine should be able to be lifted out.
    • The Taptic engine has some adhesive on the cable outlined in blue that sticks it to the speaker.
  3. Apple Watch SE Mother Board Removal, Removing the Speaker: passo 3, immagine 1 di 3 Apple Watch SE Mother Board Removal, Removing the Speaker: passo 3, immagine 2 di 3 Apple Watch SE Mother Board Removal, Removing the Speaker: passo 3, immagine 3 di 3
    • Disconnect this connector.
    • Then remove these 3 tri-screws.
  4. Apple Watch SE Mother Board Removal, Removing the Speaker pt. 2: passo 4, immagine 1 di 2 Apple Watch SE Mother Board Removal, Removing the Speaker pt. 2: passo 4, immagine 2 di 2
    • Remove the speaker slowly.
    • Where my tweezers are located seems to be the best place to remove the speaker.
  5. Apple Watch SE Mother Board Removal, Removing Brackets around the MB: passo 5, immagine 1 di 3 Apple Watch SE Mother Board Removal, Removing Brackets around the MB: passo 5, immagine 2 di 3 Apple Watch SE Mother Board Removal, Removing Brackets around the MB: passo 5, immagine 3 di 3
    • 4 more Tri-screws are removed here.
    • Gently pulling back the screen flex cables reveals 2 more Tri-screws that should be removed.
    • Then the brackets can be removed with tweezers.
  6. Apple Watch SE Mother Board Removal, Removing Brackets around the Power Button: passo 6, immagine 1 di 2 Apple Watch SE Mother Board Removal, Removing Brackets around the Power Button: passo 6, immagine 2 di 2
    • Remove these 2 Tri-screws.
    • After taking off the first bracket, take of the next Tri-screw and remove the second bracket.
  7. Apple Watch SE Mother Board Removal, Disconnecting Power button: passo 7, immagine 1 di 2 Apple Watch SE Mother Board Removal, Disconnecting Power button: passo 7, immagine 2 di 2
    • Disconnect the Power button FPC.
    • The FPC here has 2 connections. DO NOT pry in the middle as it may bend.
  8. Apple Watch SE Mother Board Removal, Removing the MB.: passo 8, immagine 1 di 3 Apple Watch SE Mother Board Removal, Removing the MB.: passo 8, immagine 2 di 3 Apple Watch SE Mother Board Removal, Removing the MB.: passo 8, immagine 3 di 3
    • Starting in the bottom right corner as show here. Gently wedge in a spudger and pry up on the board.
    • Once you are able to get a good hold on the board move try pulling down and to the right in a clockwork motion.
    • Do this motion slowly as there is a final connector under the board.
  9. Apple Watch SE Mother Board Removal, Completion: passo 9, immagine 1 di 1
    • Once the board is lifted out, the final connector is highlighted.
    • Disconnect and you are all done!
    • Repeat steps backwards to put everything back together.
jessepugsley
Membro da: 01/21/20
169 Reputazione
1 Guida realizzata
Un commento
thank you so much
Wesleyfraga - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 128
Tutti i Tempi: 3,106
