Salta al contenuto principale
Apple TimeCapsule A1355 opening for repair
  1. Apple TimeCapsule A1355 opening for repair, cutting the rubber: passo 1, immagine 1 di 3 Apple TimeCapsule A1355 opening for repair, cutting the rubber: passo 1, immagine 2 di 3 Apple TimeCapsule A1355 opening for repair, cutting the rubber: passo 1, immagine 3 di 3
    • all measures are with the rubber still on. and it stays on.
    • first you take a cutter and cut little squared or circles or what you prefer into the rubber. and then, f.e with the screwdriver tear of the rubber on the incicion you just did.
    • there are exact measures in millimetres. I recommend to turn the TimeCapsule with connections facing you and then start from the lower left corner.
    • fyi: 1 inch = 25,4 mm, 1 feet = 304,8 mm
    • Note: the green lines indicate that the screws are in alignment with each other.
    • Note: the different color circles indicate screws. I found only the 1. gen TimeCapsule sometimes be having the purple screws. with the 2.,3.,4. Generation I never found the purple ones.
  2. Apple TimeCapsule A1355 opening for repair, different generations: passo 2, immagine 1 di 1
    • the first generation is sometimes different. I had ones where in the purple markers are screws . sometimes they are reveted from the other side, and must not be removed.
    • the 2,3,4 generation have almost the same screws. sometimes the brown ones dont exist.
  3. Apple TimeCapsule A1355 opening for repair, opening the box: passo 3, immagine 1 di 1
    • turn the TimeCapsile 90D clockwise.
    • then get something where you can lean on the opened but still connected part. (in my case I used another time capsule for it)
    • then carefully open the lid to the left. and carefully put it aside like shown on the picture
    • after that you can do inside whatever you desire. in my case I took out the hard drive
  4. Apple TimeCapsule A1355 opening for repair: passo 4, immagine 1 di 1
    • if you are nerdy or have too much time on your hand, you can keep the cut-out rubber pieces and after replacement you can glue the right parts back in.
    • note: nobody sees the bottom of the TimeCapsule in general.
    • so I did not.
    • ENJOY
Conclusione
Altre 4 persone hanno completato questa guida.
Martin David
Membro da: 05/27/13
244 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 195
Tutti i Tempi: 3,071
