Salta al contenuto principale
Apple Time Capsule Model A1302 Power Supply Replacement
Cosa ti serve
  1. Apple Time Capsule Model A1302 Power Supply Replacement, Remove the rubber base: passo 1, immagine 1 di 2 Apple Time Capsule Model A1302 Power Supply Replacement, Remove the rubber base: passo 1, immagine 2 di 2
    • Place a piece of cloth or a similar soft material on a clean, flat surface. Place the device upside down on top of the fabric.
    • Open the Time Capsule by exposing the screws that hold the device together. The screws are concealed by the rubber base, which is the bottom surface of the device.
    • Use a heat gun or hair dryer to heat the rubber base, which softens the adhesive holding it on.
    • Starting in a corner, carefully lift the rubber base to prevent tearing. You can use a guitar pick or a small, plastic ruler to help separate the rubber from the metal.
    • Take your time to prevent tearing the adhesive. Ensure that you don't overheat the device.
    • If you tear some of the adhesive, don't worry. The existing adhesive is more than enough to allow the rubber base to stick back onto the unit during reassembly.
    • During reassembly, you can apply heat to the rubber base. This will enable the adhesive to flow and form a better bond with the device's metal casing.
    Slowly start peeling at one corner... worked better than shown on the pictures.
    Markus - Replica
    Slow down particularly near the bottom label where it is stiffer. Either that or I needed to give it more heat. Going too fast can risk tearing the rubber base if the adhesive is strong.
    ElvinC - Replica
    If you are wondering if the Time Capsule will still work as a router if you remove the HDD and leave it out, the answer (according to another webpage I read) is YES, it will still work. Apparently, you get a warning with the AIrPort Utility about a missing HDD, but it still works. I wanted to keep and reuse the 1TB Hitachi HDD for offsite data backup.
    CraigH - Replica
    Use an iron instead of a heating gun or hairdryer!
    Gradually raise the temperature while checking for separation, while moving over the rubber. I first cleaned the rubber with some soap, to avoid scorching dust or grease. The setting for synthetic fabrics seemed to do the job with my Tefal iron; probably a little over 100 degrees centigrade. No steam off course!
    Worked like a charm without leaving almost any residual glue.
    Sticking the rubber sole back after the repair was also successful.
    Frits de Bruijn - Replica
    Thanks for sharing this.
    kenatkenichikato - Replica
    Adhesive tape used is Nitto No. 5015. I found a piece of a back-paper left underneath the rubber…
    vesa - Replica
    Is there a possibility to change an already changed 2TB SATA to a bigger one? Mine is full. because I added another MacBook Pro, but I’d rather not buy a newer TimeCapsule
    Bette Rose - Replica
    I have a heater plate from my beer fermenting days. Sat the router on this rubber side down for an hour or so and the rubber came off easily and cleanly. A pet bed heater may work just as nicely.
    publiclee - Replica
  2. Apple Time Capsule Model A1302 Power Supply Replacement, Remove the screws: passo 2, immagine 1 di 2 Apple Time Capsule Model A1302 Power Supply Replacement, Remove the screws: passo 2, immagine 2 di 2
    • Once the rubber base is separated from the device, remove the 8 Phillips PH00 screws that attach the metal bottom of the case to the plastic top of the case.
    • Use the Philiips #00 Screwdriver.
    • Some revisions of the Time Capsule have 10 screws. The A1254 revision has two screws in the upper right and lower left corners, as shown in the second image. In this situation, be sure to remove all 10 screws.
    Confirmimg 10 screws for Model A1355
    pkeenan8 - Replica
    Larger screwdriver size can help with sticky screws.
    ElvinC - Replica
    One of my screws was already stripped by Apple, so I had to drill it out.
    CraigH - Replica
    Instead of removing the rubber floor, I cut windows in the rubber base at the designated places and dug them out. To do this, I had rectified the photo and printed it out as a square with an edge length of 19.8 cm and used it as a stencil.
    Statt den Gummiboden zu entfernen, habe ich an den bezeichneten Stellen Fenster in die Gummiplatte geschnitten und ausgehoben. Dazu hatte ich das Foto entzerrt und als Quadrat mit der Kantenlänge 19,8 cm ausgedruckt und als Schablone benutzt.
    Markus Kluft - Replica
  3. Apple Time Capsule Model A1302 Power Supply Replacement, Open the Time Capsule: passo 3, immagine 1 di 2 Apple Time Capsule Model A1302 Power Supply Replacement, Open the Time Capsule: passo 3, immagine 2 di 2
    • Position the rear side of the device (the side with Ethernet connectors) so that it is facing you.
    • Lift up the left side of the metal plate and slowly flip it over the right edge of the device.
    • To prevent damage, do not lift the metal plate straight up or use force. As shown in the second picture, the fan is attached to the metal plate and connected to the logic board next to the power connector.
    • Since many people have had serious problems with the fan power connnector breaking, it is advisable to NOT try to disconnect the fan power connector. Be VERY careful with this connector. It is extremely fragile. If you absolutely have to disconnect the fan from the logic board, VERY carefully use a spudger or tweezers to do so.
    It is really not necessary to disconnect the fan and you risk breaking it off of the logic board. :(
    rdemby - Replica
    I'd destroyed the connection between my fan and logic board by trying to remove the fan. This is a bigger problem than a broken hard drive. DO NOT TRY TO DISCONNECT THE FAN. Instead be careful with the base (making sure not to stretch the fan wire) as your proceed to step four.
    redmonton11 - Replica
    I wish I had read the comments too!! DO NOT try to disconnect the fan!!!! The connector broke off with out a lot of force. Now I have a worthless piece of metal and plastic!!!!
    mightyquinn6362 - Replica
    This is not my guide, but in order to try to prevent future damage, I've edited the guide to warn against disconnecting the fan from the logic board. Hopefully the update will be approved soon :0\
    Jeff G -
    Replaced 2 x 1500 uF capacitors ant the Time capsule is back to work !
    Thanks for this guide.
    gilberto - Replica
    I had no issues removing the fan plug from the board.
    angelopadilla - Replica
    I used a block to lean the cover on so it didn't fall completely flat on the surface. The wire connecting the fan is too short for that.
    pkeenan8 - Replica
    It seems to me that the fan on the lid is not installed correctly. The air intake is blocked by a lid. The exhaust rests against the hard drive. It is more logical to turn the fan over, then the air intake will open, and the air flow will be along the components of the motherboard
    Вячеслав Ефименко - Replica
  4. Apple Time Capsule Model A1302 Power Supply Replacement, Power Supply: passo 4, immagine 1 di 2 Apple Time Capsule Model A1302 Power Supply Replacement, Power Supply: passo 4, immagine 2 di 2
    • Power supply shown in blue
    • Start by removing the AC plug by lifting it straight up.
    should read "remove the AC plug" -- it's not a DC plug (as that's what the mains lead plugs into :)
    Lawrence Conroy - Replica
  5. Apple Time Capsule Model A1302 Power Supply Replacement: passo 5, immagine 1 di 3 Apple Time Capsule Model A1302 Power Supply Replacement: passo 5, immagine 2 di 3 Apple Time Capsule Model A1302 Power Supply Replacement: passo 5, immagine 3 di 3
    • Using a spudger, unplug the cable that supplies the motherboard with power. There's a clip to release the locking mechanism; make sure to press and release the clip before pulling up on the connector.
    • Then, using the same spudger, unplug the HDD power cable.
    • If you're not used to working with data plugs in tight spaces it could be a good idea to remove the HDD first. Consult the HDD removal guide for instructions.
    When I did this with a version 1 TC, I found it easier to pull out the SATA plug first to move it out the way, then squeeze the clip on the motherboard power connector while pulling it up (with the other hand). I have fat fingers, but this way worked for me.
  6. Apple Time Capsule Model A1302 Power Supply Replacement: passo 6, immagine 1 di 2 Apple Time Capsule Model A1302 Power Supply Replacement: passo 6, immagine 2 di 2
    • Lift the power supply out of its mountings.
    • The mounts can snag the motherboard somewhat. Just fiddle it a little and it will come loose.
Conclusione
Altre 93 persone hanno completato questa guida.
rousp
Membro da: 02/18/10
6.658 Reputazione
4 Guide realizzate
13 Commenti
Hi there,
thanks a lot for this topic,
I have no problems getting there to change the power supply, my only concern is where can i find a replacement power supply?
thanks
flow sebastien - Replica
as with sebastien... I too need to replace the power supply... but the power supply page is blank. Can someone please advise?
Michael - Replica
Hi there,
if you like me want the cheapest repair for your time capsule, it is possible to repair the power supply for as less as 2$
http://raphsallyoucanknow.blogspot.ch/20...
raphael - Replica
Hello,
Nice guide!
However, where can we find a reliable power supply?
Muchas gracias!!
Valyno
valyno - Replica
The power supply has electrolytic condensers. they age: the electrolyte evaporates, or the leads corrode. you can solder them out and replace them. mine died after 6 years because the 39uF 400volt, the long ones kicked the bucket. i replaced them for 5euro each and my unit is back online
wilfried - Replica
Wilfried - is there a way to know which capacitors are dead/need to be replaced? It looks like you had to replace: "39uF 400volt, the long ones", and Jorcorand had to replace "2 x 1500 uF capacitors". Are they the same or different? Are there more to choose from? What's the best way to identify the dead ones?
Joshua -
Thank you very much for this guide.
I had to replace 2 x 1500 uF capacitors ant the Time capsule is back to work...It's amazing when you see the Time Capsule lights turn on again!! :)
Jorcorand - Replica
Very good resource - Thank you! But where can I purchase the part? Please advise! Thanks again!
P Kahn - Replica
Thanks, I recently moved to a new house, and of course reinstalled my old TC (model A1355). When I plugged it in, nothing, no light. Following the above instructions, I removed the rubber-foot and plugged it in again. The TC worked again. A few days later, with the TC unpowered for two days, when powered, no light, the TC did not work. Heated the base of the unit again with a hairdryer a bit, plugged it in, all was working fine again.
janopdebeeck - Replica
This was a very helpful set of instructions. My A1302 is up and running again! Thanks!
I simply removed and checked all the capacitors. Different brands were used: Rubycon, Samson, Koshin and Su’scon. I simply used the capacitance checker on my multimeter. Only the Su’scon capacitor’s capacitance appeared to be about 50% below spec! In fact, very much in line with the quality ranking published on good’ol Tom’s Hardware (https://www.tomshardware.com/reviews/pow...). Eventually replaced all capacitors for which I could buy a replacement at the local electronic components store; a bike ride distance. The 47uF’s (C3 and C4) were the only ones for which I couldn’t find a replacement so quickly; they were still within spec, so I placed them back.
After replacement of the other capacitors, I added the (repaired) power-unit cover and the machine became alive again.
Great Guide :).
My Power supply is broken. Question: It’s a 614-0464 (12 V - 1 A / 5.1 V - 4.3A). Is it possible to use a 614-0440 (12 V - 1.2 A / 5.1 V - 3.8 A)? We have 220/230 V.
Thanks for help,
Dikki
Dikki Dikkison - Replica
yea I think so, no problem if it has more power, problem is if it has less
Maxi - Replica
I bought the power supply on eBay and followed the instructions. Now everything is working like the first day! Moreover, with the old one and a soldering iron I will have a replacement. Thanks a lot!!
Peter - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 79
Tutti i Tempi: 109,399
