Salta al contenuto principale
Apple Time Capsule Model A1254 Back Plate Replacement
Cosa ti serve
    1. Apple Time Capsule Model A1254 Back Plate Replacement, Back Plate: passo 1, immagine 1 di 3 Apple Time Capsule Model A1254 Back Plate Replacement, Back Plate: passo 1, immagine 2 di 3 Apple Time Capsule Model A1254 Back Plate Replacement, Back Plate: passo 1, immagine 3 di 3
      • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
      • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
      • Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
      • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
      Chiedi a FixBot
      Aggiungi Commento
    2. Apple Time Capsule Model A1254 Back Plate Replacement: passo 2, immagine 1 di 2 Apple Time Capsule Model A1254 Back Plate Replacement: passo 2, immagine 2 di 2
      • Remove the ten 3mm screws with a Phillips #00 screwdriver.
      • The screws with adhesive covering do not need to be removed.
      Chiedi a FixBot
      Aggiungi Commento
    3. Apple Time Capsule Model A1254 Back Plate Replacement: passo 3, immagine 1 di 2 Apple Time Capsule Model A1254 Back Plate Replacement: passo 3, immagine 2 di 2
      • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
      • Pull the base of the wire close to the logic board and the connector will pop off.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 9 persone hanno completato questa guida.
Cal Poly, Team 4-2, Livingston Fall 2016 Membro di Cal Poly, Team 4-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G2
4 Membri
25 guide realizzate
2Commenti sulla guida
I had to open to destroy the hard drive for security reasons. The rubber bottom was so old it just tore to bits. I used a Dremel Multi-Max with a flat scraper blade to remove it in the end.
steve - Rispondi Condividi
must I put back on the rubber bottom or can I leave it off for maximum airflow?
Strider - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 19
Ultimi 30 giorni: 65
Tutti i Tempi: 8,113
