Salta al contenuto principale
Apple Thunderbolt Display Fan Replacement
Cosa ti serve
  1. Apple Thunderbolt Display Fan Replacement, LCD: passo 1, immagine 1 di 3 Apple Thunderbolt Display Fan Replacement, LCD: passo 1, immagine 2 di 3 Apple Thunderbolt Display Fan Replacement, LCD: passo 1, immagine 3 di 3
    • Lay down the display with screen side up.
    • Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base.
    • Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
    • The glass screen is connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
  2. Apple Thunderbolt Display Fan Replacement: passo 2, immagine 1 di 2 Apple Thunderbolt Display Fan Replacement: passo 2, immagine 2 di 2
    • Unscrew the 12 screws around the side edges and the top of the LCD with the TR 10 Screwdriver.
  3. Apple Thunderbolt Display Fan Replacement: passo 3, immagine 1 di 2 Apple Thunderbolt Display Fan Replacement: passo 3, immagine 2 di 2
    • Slowly lift the LCD out from its placement and tilt it upwards.
    • It can be very helpful to have an extra set of hands to hold the LCD up while you work with the cables underneath.
    • There are four wires that connect the LCD to the rest of the components. Make sure not to pull hard and break any of the wires.
  4. Apple Thunderbolt Display Fan Replacement: passo 4, immagine 1 di 3 Apple Thunderbolt Display Fan Replacement: passo 4, immagine 2 di 3 Apple Thunderbolt Display Fan Replacement: passo 4, immagine 3 di 3
    • For the first of the four wires (furthest away from the wire that is held in by a screw), grab onto the connector and pull slowly.
  5. Apple Thunderbolt Display Fan Replacement: passo 5, immagine 1 di 3 Apple Thunderbolt Display Fan Replacement: passo 5, immagine 2 di 3 Apple Thunderbolt Display Fan Replacement: passo 5, immagine 3 di 3
    • For the next connector, which is right next to the previous wire, there is a piece of tape attached to a metal bar.
    • Flip the metal bar over using the tape as a handle.
    • Next, grab onto the connector and slowly pull it from the socket in the logic board.
  6. Apple Thunderbolt Display Fan Replacement: passo 6, immagine 1 di 3 Apple Thunderbolt Display Fan Replacement: passo 6, immagine 2 di 3 Apple Thunderbolt Display Fan Replacement: passo 6, immagine 3 di 3
    • For the connector on the other side of the logic board, grab the connector from underneath and carefully pull it from the board.
  7. Apple Thunderbolt Display Fan Replacement: passo 7, immagine 1 di 1
    • For the last wire connecting to the LCD, use your T 10 Screwdriver to remove the screw.
  8. Apple Thunderbolt Display Fan Replacement: passo 8, immagine 1 di 2 Apple Thunderbolt Display Fan Replacement: passo 8, immagine 2 di 2
    • The LCD has now been fully disconnected from the casing and can be repaired/replaced!
    • its best to set the LCD on a bed or on a thick towel to avoid damage to the LCD
  9. Apple Thunderbolt Display Fan Replacement, Fan: passo 9, immagine 1 di 1
    • Now you should have access to the rest of the display. From here, locate the fan.
  10. Apple Thunderbolt Display Fan Replacement: passo 10, immagine 1 di 3 Apple Thunderbolt Display Fan Replacement: passo 10, immagine 2 di 3 Apple Thunderbolt Display Fan Replacement: passo 10, immagine 3 di 3
    • The fan is connected to the main logic board by two connectors. Make sure that while disconnecting them, grab the wire at the point closest to the board and the pull slowly to avoid damaging the connectors.
    • Remove the piece of tape that is holding the wires to the casing.
  11. Apple Thunderbolt Display Fan Replacement: passo 11, immagine 1 di 2 Apple Thunderbolt Display Fan Replacement: passo 11, immagine 2 di 2
    • Next, you can see that the fan is connected to the casing by three screws.
    • Use the TR 10 screwdriver to remove these three screws.
  12. Apple Thunderbolt Display Fan Replacement: passo 12, immagine 1 di 1
    • Make sure to carefully remove the fan after it is free of the casing as to not damage surrounding parts.
    • Switch out the old fan with the new one and you're all set!
Conclusione
Altre 28 persone hanno completato questa guida.
Calvin Laverty
Membro da: 04/14/15
2.268 Reputazione
4 Guide realizzate
Cal Poly, Team 5-11, Maness Spring 2015 Membro di Cal Poly, Team 5-11, Maness Spring 2015
CPSU-MANESS-S15S5G11
4 Membri
19 Guide realizzate
10 Commenti
I have been having trouble with fan noise -- a noisy, rapid thumping sound, especially on startup but getting worse over a few weeks and lately persisting all day. Following this excellent guide, I removed the fan and examined it. I could see nothing wrong except perhaps a fine layer of dust on the blades, no worse than could be expected. I did not manage to disassemble the fan itself, as its two-part housing is very firmly clipped together, but applied a vacuum cleaner hose to both the entry and exit sides to clean it up as much as possible. I put it back and reassembled the whole display, and am pleased to report that the noise has completely disappeared. This may be good news to anyone dismayed by the apparent non-availability of replacement fans.
John Canti - Replica
This guide made the power supply replacement quick and easy.
Jon Martinez - Replica
I had the rumbling fan cleaned by a pro. but the rattling didn't go. I just finished replacing the fan on my 27'' Thunderbolt Display using these instructions, and so far so good after 3 hours. It usually started the rattling after 30mn!
I purchased the fan on eBay. There were a couple available then.
I got the fan for $18 and spent 30mn on the job. At the Apple certified spot in town, they were going to charge me $250! I bought this Apple Display second hand for $250! and now it is back to its old self, working like a charm :)
Thank you very much for this web page which walked me through the process.
By the way, for a succion cup I used the two small ones that are attached to my soap holder, from the bathroom tiled wall; worked just fine and I didn't have to spend $20 to buy one.
cheers
ekoh dubois - Replica
Many thanks to Mr. Laverty and the other contributors. I followed this guide to install a new power supply in my darkened 27” Thunderbolt Display to bring it back from the dead. While the instructions were specifically for replacing the fan, I found that after following them to remove the LCD panel, it was easy to replace the power supply as well. For anyone else who may suspect a failed power supply (loud buzzing and then black), I ordered mine directly from China, supposedly a brand new one. It looks identical to the original in every way and does have a 2018 sticker affixed to it. It took a month to arrive but did the trick. I paid $70.50 for it from wwon_one off eBay (https://www.ebay.com/itm/273134311780). Thanks again for the extremely helpful guide!
ilovemybeagles - Replica
Many thanks to Mr. Laverty and the other contributors. I followed this guide to install a new power supply in my darkened 27” Thunderbolt Display to bring it back from the dead. While the instructions were specifically for replacing the fan, I found that after following them to remove the LCD panel, it was easy to replace the power supply as well. For anyone else who may suspect a failed power supply (loud buzzing and then black), I ordered mine directly from China, supposedly a brand new one. It looks identical to the original in every way and does have a 2018 sticker affixed to it. It took a month to arrive but did the trick. I paid $70.50 for it from wwon_one off eBay. Thanks again for the extremely helpful guide!
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 106
Tutti i Tempi: 22,647
