Salta al contenuto principale
Apple TV 4K Logic Board Replacement
Cosa ti serve
  1. Apple TV 4K Logic Board Replacement, Logic Board: passo 1, immagine 1 di 1
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
  2. Apple TV 4K Logic Board Replacement: passo 2, immagine 1 di 2 Apple TV 4K Logic Board Replacement: passo 2, immagine 2 di 2
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
  3. Apple TV 4K Logic Board Replacement: passo 3, immagine 1 di 2 Apple TV 4K Logic Board Replacement: passo 3, immagine 2 di 2
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
  4. Apple TV 4K Logic Board Replacement: passo 4, immagine 1 di 1
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
  5. Apple TV 4K Logic Board Replacement: passo 5, immagine 1 di 3 Apple TV 4K Logic Board Replacement: passo 5, immagine 2 di 3 Apple TV 4K Logic Board Replacement: passo 5, immagine 3 di 3
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
Conclusione
Altre 8 persone hanno completato questa guida.
Keenan Barber
Membro da: 10/04/18
1.159 Reputazione
3 Guide realizzate
UW Stout, Team S6-G3, Ogden Fall 2018 Membro di UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
4 Membri
15 Guide realizzate
8 Commenti
Where does one get a new logic board??
MP94025 - Replica
Any idea on where I can purchase. new logic board?
tylerchumchal - Replica
Where do you buy the board…….
Andy Grichtmeier - Replica
Good job on showing how to remove and replace logic board. Now as the other three commentators have asked
, where can you buy another one or is an exercise in futility
Kanehoe - Replica
Hm. Has anyone’s Apple TV 4k logic board failed?
oTWR - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 118
Tutti i Tempi: 8,129
