Salta al contenuto principale
Apple TV 3rd Generation Logic Board Replacement
Cosa ti serve
  1. Apple TV 3rd Generation Logic Board Replacement, Snap-on Base: passo 1, immagine 1 di 1
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
    where so i find a new base to replace it with
    sharpeEZz - Replica
  2. Apple TV 3rd Generation Logic Board Replacement: passo 2, immagine 1 di 1
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
  3. Apple TV 3rd Generation Logic Board Replacement, Logic Board: passo 3, immagine 1 di 1
    • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
  4. Apple TV 3rd Generation Logic Board Replacement: passo 4, immagine 1 di 2 Apple TV 3rd Generation Logic Board Replacement: passo 4, immagine 2 di 2
    • Disconnect the power supply connector from the logic board with a spudger.
Conclusione
Altre 10 persone hanno completato questa guida.
Vincent Monteil
Membro da: 07/06/13
6.975 Reputazione
19 Guide realizzate
4 Commenti
Where can I find a 3rd Generation Apple TV Logic Board?
Ricky Vaughn - Replica
Good question! Did you manage to find a replacement?
Nathan Bugeja -
Hi my wifi and athernet is not working in apple tv on screen it showing your apple tv is connected to local network its not connect to internet now how should i repair this
Mohamed Iqbal Sayyed - Replica
Mine too, where could I find a logic board replacement???
Juan Ignacio Gutierrez I. -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 9,685
