Salta al contenuto principale
Apple TV 2nd Generation Bottom Cover Replacement
Cosa ti serve
  1. Apple TV 2nd Generation Bottom Cover Replacement, Bottom Cover: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Metal Spudger
    $2.99
    Compra
    • As the Apple TV doesn’t have any visible screws or points of entry, the first step is to use a couple of metal spudger to carefully loosen and remove the rubber base/bottom cover from the upper case.
  2. Apple TV 2nd Generation Bottom Cover Replacement: passo 2, immagine 1 di 1
    • Position the replacement base over the exposed interior of the Apple TV. Gently press the cover down into the Apple TV until the interior tabs snap into place and the base is attached securely to the upper case.
Conclusione
Areej Bashawiri
Membro da: 09/28/17
201 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,101
