Salta al contenuto principale
Apple Studio Display M7649 USB Port Replacement
Cosa ti serve
  1. Apple Studio Display M7649 USB Port Replacement, Stand: passo 1, immagine 1 di 2 Apple Studio Display M7649 USB Port Replacement, Stand: passo 1, immagine 2 di 2
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 USB Port Replacement, Panels: passo 2, immagine 1 di 1
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 USB Port Replacement: passo 3, immagine 1 di 1
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 USB Port Replacement: passo 4, immagine 1 di 1
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  5. Apple Studio Display M7649 USB Port Replacement, Metal EMI Shield: passo 5, immagine 1 di 1
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  6. Apple Studio Display M7649 USB Port Replacement: passo 6, immagine 1 di 1
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
  7. Apple Studio Display M7649 USB Port Replacement: passo 7, immagine 1 di 2 Apple Studio Display M7649 USB Port Replacement: passo 7, immagine 2 di 2
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
  8. Apple Studio Display M7649 USB Port Replacement, USB Port: passo 8, immagine 1 di 1
    • To remove the USB port, remove these four screws holding down the port and metal brackets.
    • There may be a zip tie you need to cut that is attaching the USB unit to the display
  9. Apple Studio Display M7649 USB Port Replacement: passo 9, immagine 1 di 1
    • Remove the cable from the logic board that is connecting the USB port.
  10. Apple Studio Display M7649 USB Port Replacement: passo 10, immagine 1 di 1
    • Remove the USB port
Conclusione
Andrew Tsao
Membro da: 01/19/10
186 Reputazione
5 Guide realizzate
Cal Poly, Team 3-20, Maness Winter 2010 Membro di Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 20
Tutti i Tempi: 3,228
