Salta al contenuto principale
Apple Powerbook 5300 Hard Drive Replacement
Cosa ti serve
  1. Apple Powerbook 5300 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Hard Drive Replacement, Keyboard: passo 2, immagine 1 di 1
    • Turn the laptop over and remove the three T8 torx screws from the bottom panel.
  3. Apple Powerbook 5300 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Turn the laptop back over and open the monitor.
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use a spudger to lift the white plastic retainer about 1/16" to release the cable.
    Use a spudger under one of the keys on the bottom row to very gently lift until you can use your hand to lift the keyboard.
    Mike Jackson-Polek - Replica
    I tried to use those ifixit spudgers with several powerbooks to lift the white plastic retainers but it's too risky.. tiny, fragile, brittle plastics. I now use regular L-shaped tweezers, much safer, more control.
    Jamba - Replica
  4. Apple Powerbook 5300 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 2 Apple Powerbook 5300 Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 2
    • Gently lift up the laptop's front-most panel and slowly raise the trackpad from the logic board.
    • Disconnect the front panel's ribbon cable from the board by slowly pulling it out of the connection port. Set the panel aside.
  5. Apple Powerbook 5300 Hard Drive Replacement: passo 5, immagine 1 di 2 Apple Powerbook 5300 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Unscrew the Torx #8 screws holding the hard drive case in place on the logic board.
    • Lift up on the hard drive to disconnect its ribbon cable from the logic board, just like in the previous steps.
  6. Apple Powerbook 5300 Hard Drive Replacement: passo 6, immagine 1 di 2 Apple Powerbook 5300 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Unscrew the four Torx #8 screws holding the hard drive to its case.
    • The hard drive can now be removed from its encasement.
Conclusione
Altre 2 persone hanno completato questa guida.
Scott
Membro da: 04/26/11
155 Reputazione
5 Guide realizzate
Cal Poly, Team 25-30, Garner Spring 2011 Membro di Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 Membri
6 Guide realizzate
Un commento
I was very surprised to find this guide and very pleased. Good work.
mayer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 20
Tutti i Tempi: 6,149
