Salta al contenuto principale
Apple Powerbook 5300 Battery Replacement
  1. Apple Powerbook 5300 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
Conclusione
Cal Poly, Team 25-30, Garner Spring 2011 Membro di Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 3,060
