Salta al contenuto principale
Apple Powerbook 520/540 General Disassembly
Cosa ti serve
  1. Apple Powerbook 520/540 General Disassembly, Case: passo 1, immagine 1 di 2 Apple Powerbook 520/540 General Disassembly, Case: passo 1, immagine 2 di 2
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. Apple Powerbook 520/540 General Disassembly: passo 2, immagine 1 di 1
    • With monitor hinge at the bottom, remove the two top center screws.
    Not necessary for RAM, hard drive, or CPU replacement.
    Miles Raymond - Replica
    The Screws are T8!
    Willy Kaiser - Replica
  3. Apple Powerbook 520/540 General Disassembly: passo 3, immagine 1 di 1
    • Remove top left and top right screws.
    Also not necessary for RAM, hard drive, or CPU replacement.
  4. Apple Powerbook 520/540 General Disassembly: passo 4, immagine 1 di 1
    • Remove middle left and middle right screws.
  5. Apple Powerbook 520/540 General Disassembly: passo 5, immagine 1 di 1
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
    Again not necessary for RAM, hard drive, or CPU replacement.
    Philips PH00 screws
    8-Bit Hero Wendler - Replica
  6. Apple Powerbook 520/540 General Disassembly: passo 6, immagine 1 di 1
    • Lift keyboard from bottom and take out of shell.
  7. Apple Powerbook 520/540 General Disassembly: passo 7, immagine 1 di 3 Apple Powerbook 520/540 General Disassembly: passo 7, immagine 2 di 3 Apple Powerbook 520/540 General Disassembly: passo 7, immagine 3 di 3
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
Conclusione
Altre 9 persone hanno completato questa guida.
Mark McNeff
Membro da: 04/20/11
497 Reputazione
2 Guide realizzate
2 Commenti
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - Replica
Thanks been trying to fix this for a long time
Luke - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 52
Tutti i Tempi: 6,688
