Introduzione
To replace the hard-drive, one must first remove the keyboard and RAM to be ready to remove the hard drive from the computer.
Strumenti
Parti
Nessuna parte richiesta.
Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
Lift the heat shield up and toward you.
Locate the orange tab, which should be just left of the hard-drive.
You must disconnect this orange tab from the logic board to enable the next step.
It is better to do this by grabbing the plastic connection point, not the relatively flexible cable.
Altre 2 persone hanno completato questa guida.
