Salta al contenuto principale
Apple Magic Keyboard 2 A2450 Keyboard Replacement
Cosa ti serve
  1. Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: passo 1, immagine 1 di 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: passo 1, immagine 2 di 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: passo 1, immagine 3 di 3
    • Apply heat around the perimeter of the lower case to loosen the adhesive that secures the lower case to the chassis.
    • The plastic should be a bit too warm to touch comfortably, but not hot.
    • Insert an opening pick in the gap between the lower case and chassis.
    • After ensuring that the adhesive is warm, slide the pick around the perimeter to sever the adhesive.
    • As you sever the adhesive, insert additional opening picks at each corner to prevent the adhesive from readhering.
    • Remove the lower case.
  2. Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: passo 2, immagine 1 di 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: passo 2, immagine 2 di 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: passo 2, immagine 3 di 3
    • Use a T3 Torx screwdriver head to remove all twelve 5 mm that secure the midframe.
    • Use tweezers to disconnect the battery motherboard connection.
    • Remove the midframe.
  3. Apple Magic Keyboard 2 A2450 Keyboard Replacement: passo 3, immagine 1 di 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: passo 3, immagine 2 di 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: passo 3, immagine 3 di 3
    • Use a T3 Torx screwdriver to remove the two 5 mm screws that secure the lightning port.
    • Use tweezers to remove the Lighting port from the motherboard.
  4. Apple Magic Keyboard 2 A2450 Keyboard Replacement: passo 4, immagine 1 di 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: passo 4, immagine 2 di 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: passo 4, immagine 3 di 3
    • Use a T3 Torx screwdriver to remove the three 3 mm screws that secure the motherboard.
    • Remove the tape covering the ribbon cable on the top half of the motherboard.
    • Use a small pair of tweezers to gently unplug the ribbon cable and remove the motherboard from the keyboard.
  5. Apple Magic Keyboard 2 A2450 Keyboard Replacement: passo 5, immagine 1 di 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: passo 5, immagine 2 di 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: passo 5, immagine 3 di 3
    • Use a T3 Torx screwdriver to remove the single 3 mm screw that secures the assembly to the frame.
    • Use tweezers to unplug the power switch from the case. Pull horizontally on the entire assembly to remove the switch from the keyboard.
  6. Apple Magic Keyboard 2 A2450 Keyboard Replacement: passo 6, immagine 1 di 1
    • Replace the keyboard.
Conclusione
Alex
Membro da: 04/02/24
219 Reputazione
2 Guide realizzate
IUPUI, Team 3-2, Harley Spring 2024 Membro di IUPUI, Team 3-2, Harley Spring 2024
IUPUI-HARLEY-S24S3G2
4 Membri
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 147
Tutti i Tempi: 2,140
