Salta al contenuto principale
Introduzione
This guide will help you remove and replace your computers speaker, if speaker is not working properly or at all.
Parti
Nessuna parte specificata.
  1. Remove the six 19 mm long screws with a #2 Phillips head screwdriver. Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Release the catch by pushing it in using a plastic opening tool. The catch is off-center, but in line with the middle of the speaker underneath.
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove. Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Skip the upgrade.
    Ottieni $10 di sconto su $50 con
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
  5. Lift the handle straight up to remove. Lift the handle straight up to remove.
    • Lift the handle straight up to remove.
  6. Tilt the keyboard up while detaching the ribbon connection by pulling it straight up.  You may have to wiggle the connector sideways to loosen it. Be careful not to force the ribbon while pulling it out to avoid tearing.  Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
  7. Unplug the speaker from the mother board by pulling horizontally.
    • Unplug the speaker from the mother board by pulling horizontally.
  8. Heat the glue to loosen it, then wiggle the speaker up and out. Use the screwdriver to scrape off the remaining glue.
    • Heat the glue to loosen it, then wiggle the speaker up and out. Use the screwdriver to scrape off the remaining glue.
    • An easy way to heat the glue is by using a hair dryer on a low setting.
    • When heating the glue, do not use any high wattage device! This may burn or damage the chips or circuit board.
Conclusione
Altre 5 persone hanno completato questa guida.
Josiah
Membro da: 06/10/2011
508 Reputazione
3 Guide realizzate
Cal Poly, Team 21-23, Maness Fall 2011 Membro di Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,038
