Introduzione
Replacing the keyboard is an easy repair that is unfortunately necessary in certain cases. This guide will take you through the process of removing your keyboard step by step.
Cosa ti serve
Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
Altre 4 persone hanno completato questa guida.
