Salta al contenuto principale
Apple IIc Keyboard Replacement
Cosa ti serve
  1. Apple IIc Keyboard Replacement, Disassembling Apple IIc Cover: passo 1, immagine 1 di 2 Apple IIc Keyboard Replacement, Disassembling Apple IIc Cover: passo 1, immagine 2 di 2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Apple IIc Keyboard Replacement: passo 2, immagine 1 di 2 Apple IIc Keyboard Replacement: passo 2, immagine 2 di 2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Apple IIc Keyboard Replacement: passo 3, immagine 1 di 2 Apple IIc Keyboard Replacement: passo 3, immagine 2 di 2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Apple IIc Keyboard Replacement: passo 4, immagine 1 di 2 Apple IIc Keyboard Replacement: passo 4, immagine 2 di 2
    • Lift the handle straight up to remove.
  5. Apple IIc Keyboard Replacement, Keyboard: passo 5, immagine 1 di 2 Apple IIc Keyboard Replacement, Keyboard: passo 5, immagine 2 di 2
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 21-23, Maness Fall 2011 Membro di Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Membri
13 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 3,702
