Salta al contenuto principale
Apple Cinema Display M8149 Voltage Inverter Replacement
Cosa ti serve
  1. Apple Cinema Display M8149 Voltage Inverter Replacement, Control Boards: passo 1, immagine 1 di 3 Apple Cinema Display M8149 Voltage Inverter Replacement, Control Boards: passo 1, immagine 2 di 3 Apple Cinema Display M8149 Voltage Inverter Replacement, Control Boards: passo 1, immagine 3 di 3
    • Before starting, make sure the display is unplugged.
    • Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
    • Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
    • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
    Mine had hex head screws instead of Phillips head.
    Bill Greene - Replica
    Hex 2.0 screws here too!
    dietrichbatista - Replica
  2. Apple Cinema Display M8149 Voltage Inverter Replacement: passo 2, immagine 1 di 3 Apple Cinema Display M8149 Voltage Inverter Replacement: passo 2, immagine 2 di 3 Apple Cinema Display M8149 Voltage Inverter Replacement: passo 2, immagine 3 di 3
    • Remove the eighteen (5.25 x 4.43 mm) screws around the edge of the backplate using the Hex key.
    • Disconnect the small white connector leading to the display's Power button.
    • Gently lift the backplate off of the display. Completely remove the backplate and set it aside.
    AND: Shall we mention right here, there is a small white connector leading to the display's POWER button that should be disconnected to slide the back plate off.
    spudmcat - Replica
    These screws too were hex head, not PH2, on my display.
    Exactly: Hex 2.0 screws
  3. Apple Cinema Display M8149 Voltage Inverter Replacement: passo 3, immagine 1 di 2 Apple Cinema Display M8149 Voltage Inverter Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the four (9.52 x 3.43 mm) screws on the outer rim of the metal cover.
    • Next, remove the four cover (11.91 x 2.89 mm) screws located at the corners of the metal cover using the Phillips #2 screwdriver.
    Here and on the next step you’ll m
    need a PH 2 screwdriver
  4. Apple Cinema Display M8149 Voltage Inverter Replacement: passo 4, immagine 1 di 3 Apple Cinema Display M8149 Voltage Inverter Replacement: passo 4, immagine 2 di 3 Apple Cinema Display M8149 Voltage Inverter Replacement: passo 4, immagine 3 di 3
    • Unplug the large brown plug in the center-right, that connects the control board to the rest of the display.
    • Unplug the blue and gray plug on the right side of the control board. Repeat with the left side.
    There are 2 Phillips screws at the center top and center bottom that need to be removed as well. They are parallel to the work surface if the screen is flat. The control board must be lifted slightly to access the screws. There's also a clip holding the disconnected power connector to the mechanisms below.
    About This Matt - Replica
  5. Apple Cinema Display M8149 Voltage Inverter Replacement: passo 5, immagine 1 di 2 Apple Cinema Display M8149 Voltage Inverter Replacement: passo 5, immagine 2 di 2
    • Gently lift the large metal cover which spans across the back of the whole display.
  6. Apple Cinema Display M8149 Voltage Inverter Replacement, Voltage Inverter: passo 6, immagine 1 di 3 Apple Cinema Display M8149 Voltage Inverter Replacement, Voltage Inverter: passo 6, immagine 2 di 3 Apple Cinema Display M8149 Voltage Inverter Replacement, Voltage Inverter: passo 6, immagine 3 di 3
    • Turn your attention to the left side of the cinema display.
    • Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board.
    • Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
    • Remove the circuit board by gently lifting it from the display.
Conclusione
Altre 3 persone hanno completato questa guida.
Brett Murphy
Membro da: 04/01/11
197 Reputazione
3 Guide realizzate
Cal Poly, Team 10-41, Forte Spring 2011 Membro di Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 Membri
12 Guide realizzate
Un commento
Brilliantly clear and simple to follow. As I suspected it was the inverter board that failed leaving me a totally black screen on my 20 year old 22 inch Cinema display (ADC). Your guide enabled me to restore the monitor to working order, and it’s now paired once again with my Apple cube. Thank you ever so much!
kevin.raddy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 4,998
