Introduzione
This guide shows the reader how to disassemble the Apple Cinema Display M8149 so that the screen can be replaced.
Strumenti
Ricambi
Nessuna parte specificata.
Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
Remove the eighteen (5.25 x 4.43 mm) screws around the edge of the backplate using the Hex key.
Disconnect the small white connector leading to the display's Power button.
Gently lift the backplate off of the display. Completely remove the backplate and set it aside.
These screws too were hex head, not PH2, on my display.
Exactly: Hex 2.0 screws
Use a Phillips #2 screwdriver to remove the four (9.52 x 3.43 mm) screws on the outer rim of the metal cover.
Next, remove the four cover (11.91 x 2.89 mm) screws located at the corners of the metal cover using the Phillips #2 screwdriver.
Carefully remove the two tape plugs on either side of the control board using a spudger.
Turn your attention to the left side of the cinema display.
Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board.
Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
Remove the circuit board by gently lifting it from the display.
Lift the screen from the surrounding front cover by sliding your fingers between the two pieces and lifting.
Altre 3 persone hanno completato questa guida.
Mine had hex head screws instead of Phillips head.
Bill Greene - Replica
Hex 2.0 screws here too!
dietrichbatista - Replica
