Salta al contenuto principale
Apple Airport Extreme Model A1408 Back Pad Replacement
Cosa ti serve
  1. Apple Airport Extreme Model A1408 Back Pad Replacement, Back Pad: passo 1, immagine 1 di 1
    • CAUTION: The heat gun and hair dryer can get very hot. Do not put your hands or any other body part too close to either device. Also, do not touch the back pad right after heating it.
    • Use a blow dryer or heat gun on a medium to high heat setting on the back pad to loosen the glue that attaches it to the device.
  2. Apple Airport Extreme Model A1408 Back Pad Replacement: passo 2, immagine 1 di 1
    • To avoid ripping the back pad, gently peel it back from one corner until the pad is completely off.
    • Use heat in areas where the glue is not loose enough.
    • You may need to reattach the back pad with double-sided tape if the glue is not tacky enough to stick the pad back on.
Conclusione
To reassemble your device, follow these instructions in reverse order without using the hair dryer.
Jada Evers
Membro da: 10/14/14
296 Reputazione
2 Guide realizzate
Cal Poly, Team 10-37, Amido Fall 2014 Membro di Cal Poly, Team 10-37, Amido Fall 2014
CPSU-AMIDO-F14S10G37
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,138
