Salta al contenuto principale
Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement
Cosa ti serve
  1. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Back Pad: passo 1, immagine 1 di 1
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
  2. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Back Cover: passo 2, immagine 1 di 1
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement: passo 3, immagine 1 di 1
    • Lift up the back case from the perforated edge to remove it.
  4. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Remove from Case: passo 4, immagine 1 di 1
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
  5. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Detach Logic Board From Case: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
  6. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Pull Back Tabs: passo 6, immagine 1 di 1
    • Carefully push back the three metal tabs with your fingers on the sides of metal case.
  7. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Remove Metal case: passo 7, immagine 1 di 1
    • Carefully pull the metal case away from the logic board.
  8. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Unhooking the WiFi Card: passo 8, immagine 1 di 1
    • Locate the WiFi card on the logic board, then use the prying tool to bend back the plastic holding it in place.
    • Be careful when prying back the plastic piece, it can break if bent too far.
  9. Apple AirPort Extreme Model A1143 Wi-Fi Card Replacement, Removing the WiFi Card: passo 9, immagine 1 di 1
    • After holding back the plastic piece keeping the card in place, lift the card up and pull it away from the logic board.
Conclusione
Zak
Membro da: 09/23/14
616 Reputazione
4 Guide realizzate
USF Tampa, Team 12-4, Blackwell Fall 2014 Membro di USF Tampa, Team 12-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G4
5 Membri
10 Guide realizzate
Un commento
What types of mini pci wifi cards are supported?
Dan S - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 3,155
