Salta al contenuto principale
Apex Tablet 7 Camera Replacement
Cosa ti serve
  1. Apex Tablet 7 Camera Replacement, Back Panel: passo 1, immagine 1 di 1
    • Unscrew the two 2.70 mm Phillips #00 screws on the side of the tablet that has the buttons and the headphone jack (bottom side when holding upright).
  2. Apex Tablet 7 Camera Replacement: passo 2, immagine 1 di 2 Apex Tablet 7 Camera Replacement: passo 2, immagine 2 di 2
    • CAUTION: When removing the back panel of the tablet, take caution around the speaker. This is located in the lower right corner when looking at the back of the tablet. There are two wires inside connecting the tablet back panel to the device itself and this connection may be severed if the back is pulled off without care.
    • This connection is shown in red on the pictures.
  3. Apex Tablet 7 Camera Replacement: passo 3, immagine 1 di 2 Apex Tablet 7 Camera Replacement: passo 3, immagine 2 di 2
    • Slide a plastic opening tool in between the edge of the back panel and the the top edge of the device.
    • Run the plastic opening tool along the sides of the tablet while keeping it in the crack between the tablet and the back panel to create an opening.
  4. Apex Tablet 7 Camera Replacement: passo 4, immagine 1 di 1
    • Apply pressure using your hand to pop the back panel off slowly, taking extra care around the speaker connection.
  5. Apex Tablet 7 Camera Replacement: passo 5, immagine 1 di 1
    • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
  6. Apex Tablet 7 Camera Replacement, Camera: passo 6, immagine 1 di 2 Apex Tablet 7 Camera Replacement, Camera: passo 6, immagine 2 di 2
    • Gently remove the black tape covering the camera and circuit board. The tape will be connected to a foamy block on the back of the actual camera component.
  7. Apex Tablet 7 Camera Replacement: passo 7, immagine 1 di 1
    • Flip the black latch over the gold cable to the upright position in order to release the cable.
  8. Apex Tablet 7 Camera Replacement: passo 8, immagine 1 di 1
    • Carefully remove the cable from the circuit by pulling it straight out.
  9. Apex Tablet 7 Camera Replacement: passo 9, immagine 1 di 1
    • Pull out the camera. There should not be any more connections holding it in place.
    • Reconnect the replacement camera.
Conclusione
To place the new part and reassemble your device, follow these instructions in reverse order.
Baylor, Team 2-2, Grigsby Spring 2015 Membro di Baylor, Team 2-2, Grigsby Spring 2015
BU-GRIGSBY-S15S2G2
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 470
