Salta al contenuto principale
Aorus X7 v2 Motherboard Replacement
Cosa ti serve
  1. Aorus X7 v2 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 Aorus X7 v2 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 Aorus X7 v2 Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    T5 Torx Screwdriver
    $5.49
    • First, power off your laptop and unplug all cables and accessories. Then, place it upside down on a stable and flat surface.
    • Use the T5 Torx Screwdriver to remove the twelve screws on the bottom of the laptop. Once the screws are removed, lift off the bottom panel.
    • Use the Phillips #0 Screwdriver to remove the twelve screws holding the heatsink in place.
    • Carefully pull the two black tabs on either side of the black ribbon to disconnect them from the board.
    • Gently pull off the inner black ribbon to remove it from the board.
    • Use the Phillips #0 Screwdriver to remove the two screws holding the mSATA.
    • With a gently tug, disconnect the four white plugs.
    • Use the Phillips #0 Screwdriver to remove the two screws holding the wireless card.
  2. Aorus X7 v2 Motherboard Replacement: passo 2, immagine 1 di 3 Aorus X7 v2 Motherboard Replacement: passo 2, immagine 2 di 3 Aorus X7 v2 Motherboard Replacement: passo 2, immagine 3 di 3
    • There are three fan plugs to disconnect. In the first photo, locate and disconnect two fan plugs by gently pulling out the black wire from the white plug.
    • Locate and disconnect the third fan plug by gently pulling out the black wire from the white plug.
    • Remove blue ribbon by gently pulling.
  3. Aorus X7 v2 Motherboard Replacement: passo 3, immagine 1 di 3 Aorus X7 v2 Motherboard Replacement: passo 3, immagine 2 di 3 Aorus X7 v2 Motherboard Replacement: passo 3, immagine 3 di 3
    $5.49
  4. Aorus X7 v2 Motherboard Replacement: passo 4, immagine 1 di 3 Aorus X7 v2 Motherboard Replacement: passo 4, immagine 2 di 3 Aorus X7 v2 Motherboard Replacement: passo 4, immagine 3 di 3
    $5.49
    • Use the Phillips #0 Screwdriver to remove the three screws on the left speaker.
    • Lift the motherboard slightly near the parallel speaker screws to find the orange ribbon underneath. Use the Blunt Nose Tweezer to gently pull it off.
    • In the same area as the blue ribbon, find the orange ribbon and gently pull it off using a pair of needle nose pliers for access to remove the motherboard.
  5. Aorus X7 v2 Motherboard Replacement: passo 5, immagine 1 di 1
    • In the location of the previously removed right speaker, carefully lift off the motherboard.
Conclusione
Complete these steps in reverse order to install your new motherboard.
Gateway, Team 1-4, Pee Fall 2022 Membro di Gateway, Team 1-4, Pee Fall 2022
GCC-PEE-F22S1G4
3 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 33
Tutti i Tempi: 758
