Salta al contenuto principale
Antique Singer sewing machine 1935 Thread adjustable guide Replacement
  1. Antique Singer sewing machine 1935 Thread adjustable guide Replacement, Missing thread guide: passo 1, immagine 1 di 1
    • The machine is missing the thread guide as shown here. Otherwise, it is operational.
  2. Antique Singer sewing machine 1935 Thread adjustable guide Replacement, Machining the elements: passo 2, immagine 1 di 2 Antique Singer sewing machine 1935 Thread adjustable guide Replacement, Machining the elements: passo 2, immagine 2 di 2
    • You will need a lathe to machine appropriately sized elements to replace the mechanism.
    • I used alumunium for the machined elements. Use high speed to obtain smooth surface as you need the thread to slide correctly.
    • The assembly may be done used an M5 screw and a cone spring as shown.
Conclusione
Michal Ruzek
Membro da: 01/27/22
739 Reputazione
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 28
Tutti i Tempi: 266
